Comptech SC tuning software???
Old Mar 1, 2011 | 09:37 AM
Js03CLS's Avatar
I am installing a Comptech SC and an AEM Methanol Injection kit on my 03 CLS 6speed. I have a AEM F/IC with it.
A somewhat local tuner told me he will not work with the F/IC due to "annoying issues".
Any recommendations on different software to use? Whats the best as far as reliability and ease of use?
Old Mar 1, 2011 | 10:04 AM
dbramaged's Avatar
I've been looking into any piggyback systems or standalone systems as well. A shop out of Denver that does amazing work told me just yesterday that with the TL or CL Type S motors&ECUs, you're SOL. Basically you need to tweak the fuel system and let the factory ECU do its job. The AEM FI/C won't do what you're looking for. It's been known to have its issues with the honda/acura four cylinders as well even though AEM hypes it up as the cure to newer OBDII cars. I wish you luck and know that the CT SC kits will come with everything needed to make the car run correctly. The additional methanol injection kit is a good addition to keep from detonating as well.
Old Mar 1, 2011 | 10:26 AM
gnuts's Avatar
3.5 psi
The emanage blue works for s/c guys well. Will you be running the high boost pulley?
If you're running the stock pulley, you don't need a piggy back. The ECM hides boost from the ECU, and the FPR is already calibrated for the s/c.
Old Mar 1, 2011 | 12:26 PM
Js03CLS's Avatar
I believe the pulley is for 5-6lbs?? I dont want to run anymore than that as it is my daily driver. When you say ECM your talking the plug and play module that comes with s/c?? Im sorry this whole Jseries stuff is very new to me so plesae excuse any stupid questions! Also what does FPR stand for?
Old Mar 1, 2011 | 12:27 PM
Js03CLS's Avatar
gnuts if I didnt just go broke from all the other crap I would buy those wheels ASAP!!!
Old Mar 1, 2011 | 12:39 PM
Js03CLS's Avatar
Wow brain fart on FPR.. nvm dont need clarification on that!
Old Mar 1, 2011 | 01:21 PM
gnuts's Avatar
3.5 psi
Ya i think that's what it's called...ECM? The little box that you wire in.
I'm not sure but i think you would need some tuning (emanage-blue) if you're running the meth kit. You'll want to make sure your air/fuel (a/f) is where you want it. You should see more power with the meth kit.
Old Mar 1, 2011 | 06:18 PM
Js03CLS's Avatar
Just spoke with ptuning out of virginia. He said they can tune it with just the AEM F/IC however they prefer the F/IC ultimate. He said the comptech ESM box is not necessary as it is just a basic map that wont help when adding the Meth injection.
Anyone ever deal with Ptuning out of virginia???
Old Mar 1, 2011 | 06:56 PM
gnuts's Avatar
3.5 psi
ya if you have additional tuning you don't need the ECM. It just hides boost, which the piggyback will do.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
