Popping noise in intake air box
Old Jul 21, 2016 | 03:21 PM
TrUcOvErDuGo's Avatar
5th Gear
My 2002 type s started to make this popping nise in intake air box. What could this be. No check engine or anything. Just a constant popping noise. Please help.
Old Jul 22, 2016 | 12:28 PM
mattcl-s's Avatar
Did you open the box to see if there was anything stuck in there?
Old Jul 22, 2016 | 01:52 PM
5th Gear
Yes I opened it and it is like some kinda of popping noise coming from intake side. Like some mini misfire or something. But odd no check engine
Old Aug 23, 2016 | 06:04 PM
joelab1's Avatar
I had the same problem after replacing the Idle Air Control with an aftermarket one. After installing a new OEM IAC, the problem went away. I read about this same issue from others after replacing a non-OEM IAC.
Old Aug 24, 2016 | 02:15 PM
mattcl-s's Avatar
Check your spark plugs It could be a broken one causing it to ark out the side. friend of mine had a similar issue
emanon256
Mar 9, 2025 06:47 PM
pwehmeier
Mar 27, 2016 10:00 AM
mugenspire
Mar 8, 2016 12:45 PM
donsor
Feb 24, 2016 03:12 PM
6spd-GERCO
22
Feb 16, 2016 07:56 PM
