Passenger door lock does not unlock from key fob.
Old 10-08-2012 | 04:38 PM
briancl's Avatar
Hey everyone! I am having a problem with my passenger door lock. Door does not unlock from the key fob or when I press lock/unlock on drivers side or when I press the lock unlock switch on the passenger door. It only locks when I pull the lock up/down or when I manually unlock using the key outside. Is this an actuator problem? Any DIY for installing actuator? Thanks for taking the time to look and I wish you all a wonderful day!
Old 10-08-2012 | 06:39 PM
briancl's Avatar
Upon doing more research, I am pretty sure it is the actuator. I wasn't able to find a DIY for the acura cl, can anyone point me to the right direction?? Thanks!
Old 10-12-2012 | 12:06 PM
Xcivicb's Avatar
Learning New Ways!
You probably tried this already but Do you press the button twice to unlock? I know mine has to be pressed twice to unlock it.
Old 10-12-2012 | 01:14 PM
Catfisha's Avatar
Giant Blue Car
To remove the passenger door panel:
https://acurazine.com/forums/showthr...ght=door+panel
https://acurazine.com/forums/audio-video-electronics-navigation-22/2nd-gen-cl-door-panel-removal-335272/
For the actuator (on a 1st gen CL):
https://acurazine.com/forums/showthr...=lock+actuator
Old 10-15-2012 | 04:24 PM
briancl's Avatar
I tried it, seems to be no reaction from the door lock.
Originally Posted by Catfisha
Thanks! I ordered the part, so now is the tough part to install. Hope it goes smoothly. Will report back!
abcman (12-29-2014)
Old 10-15-2012 | 04:44 PM
Catfisha's Avatar
Giant Blue Car
Just take your time and keep all the clips/bolts etc. in a bowl so you won't lose one!
Old 10-15-2012 | 05:04 PM
Xcivicb's Avatar
Learning New Ways!
Good luck man and take your time, like Catfisha said have a bowl and put all your clips and screws there.
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
aleo12
4G TL Problems & Fixes
09-17-2015 03:48 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
hand123
09-10-2015 09:29 AM
Quick Reply: Passenger door lock does not unlock from key fob.
