Our Fog lights
Not without modification to the housing. Since it's made of plastic, there have been members reporting that it starts to melt with the heat. You can upgrade to 12 watt bulb but I can't remember the bulb size off the top of my head. The stock sized bulbs are 5 watts.
Also please use the search function next time. This topic has been covered many times before.
lol there called road lamps. there not made for you to see but for others to see you. if you want to go hid fogs you have to go custom like i did.
http://www.flickr.com/photos/58529986@N05/6360179921/http://www.flickr.com/photos/58529986@N05/6360179921/ by http://www.flickr.com/people/58529986@N05/, on Flickr
http://www.flickr.com/photos/58529986@N05/6360186599/http://www.flickr.com/photos/58529986@N05/6360186599/ by http://www.flickr.com/people/58529986@N05/, on Flickr
Here's a website you may find helpful:
http://www.superbrightleds.com/cgi-b...FQTNKgodwiZRvg
I used these bulbs in the pictures
http://www.ledwholesalers.com/store/...&productId=458
The White, not warm
The White, not warm
The White, not warm
The White, not warm
I did notice there are two holes (upper & lower) where the bulb can go in the light housing. Current bulbs are in the lower. Any comment on this???
2013 Infiniti G37S
Do any of you guys have a photo of the LED lights showing the road ahead w/o the headlights? Its been real foggy here and I need something functional not just cosmetic. Thanks.
Whats up with RDX owners?
If you want function, stick to proper halogen fogs (HID, since the are so close to the ground, will glare, especially on wet roads).
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
@Mikeshlong On IG
![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
EDIT: Link if possible please , I've always wanted to change out my halogens to those
http://www.ledwholesalers.com/store/...&productId=688
It should be the 18 LED wedge bulb, make sure you get the "white" and NOT the "warm white" if you want it to look like mine
You would have to have a second set of housings to revert back
When you take the housings out and the hole in which the bulb locks into you have to cut out the teeth in the hole that lock in the bulbs. I used a heated knife and melted through them
mikebikelife (07-06-2012)
2003 CL
HID bulb in the road lamp housing
This is how I approached the driving light situation: I added the 2003/2005 2 door Accord driving light kit to my CL.
![](http://i999.photobucket.com/albums/af113/hotclick56/Accord-fog-light-kit.jpg)
But instead of using the halogen bulbs, I used the H11 Osram 5500K HID bulb and the wiring harness from the www.retrofitsource.com
http://www.theretrofitsource.com/pdf...on_Harness.pdf
And here is how my CL looked like:
![](http://i999.photobucket.com/albums/af113/hotclick56/IMG_0114b.jpg)
99 Chris (10-03-2012)
I like peanut butter
hey seymore, check this link out....i want to get the fogs changed to led will they fit http://www.ebay.com/itm/Car-T20-5050...3266b9&vxp=mtr
