Ok... so i searched the posts
Old Feb 16, 2008 | 10:32 PM
Black Hawk Cl's Avatar
Loving the Drive
Question Ok... so i searched the posts
now i need help. my car started this whole "octane knock" nonsense. Some ppl call it pinging. Can anyone explain to me the definition of pinging is? and how can i get rid of it? it doesnt do it that much, but when it does, its annoying. pls, help...
Old Feb 17, 2008 | 07:35 AM
Zippee's Avatar
Pinging, properly known as pre-ignition, happens when the fuel in the cylinder ignites due to pressure rather than when the spark plug fires. Cure is to use a higher octane fuel.
Old Feb 17, 2008 | 01:32 PM
fuzzy02CLS's Avatar
Ans since the CL has the EGR & MAP sensors to help eliminate this I'd bet 1 of those are bad. If your hear pinging you have either a fuel or spark problem. That would lead to questions like...
How many miles on the car?
When was the last time you cleaned the sensors & TB?
How are your spark plugs?
Are you using 91+ gas?
Old Feb 17, 2008 | 07:09 PM
Loving the Drive
ok, i have 127k on a 01 cls. i havent cleaned the tb or the map sensors. ill do that on tuesday and see what happens. i jus changed the plugs about august of last year (what a headache) and i only use premium gas. any suggestions?
and thanks ZIPPEE for the definition.
i also cleaned the fuel system about three months ago. this jus started happening about two weeks ago, atleast i noticed it two weeks ago.
Old Feb 17, 2008 | 10:35 PM
fuzzy02CLS's Avatar
Are you sure you got the correct plugs? You may want to take a few out & check them. If they seem burnt or oil soaked you have a problem.
Old Feb 17, 2008 | 11:57 PM
Loving the Drive
wat plugs are recommended? i used bosch double platinum...
Old Feb 18, 2008 | 06:14 AM
fuzzy02CLS's Avatar
Not those. That may be your problem.
NGK PZFR5F-11
or
DENSO PKJ20CR-M11
The CLS also takes an Iridium plug not platinum.
They should also come pre-gapped to 0.044" = 1.1mm
Old Feb 18, 2008 | 08:07 PM
Loving the Drive
Thanks fuzzy. Will fix that tomorrow. man, i love this place.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
urbtsx
Mar 4, 2017 06:53 PM
corybgee
ILX
28
Oct 2, 2015 07:06 PM
