Need to Replace my key and remote? Best Place to purchase from?
I need to get a set of replacement keys and remotes. I purchase a key off ebay and brought it to my dealer and unfortunetly they would not program it.
How much do they cost? Any suggestions on where to purchase them?
Covered in our helpful FAQ...
https://acurazine.com/forums/2g-cl-2001-2003-50/%2A%2A%2A-official-2nd-gen-cl-information-thread-%2A%2A%2A-480087/
here ya go! go to ebay and buy one, then use this guide. very simple.
Steps
[edit] Tips
Steps
- Gather all remotes for the vehicle on hand. You only need one remote to get into program mode but all remotes must be programmed during the same session. The car will "forget" previous remotes everytime it is reprogrammed.
- Sit in the car with all doors/trunk tightly closed.
- Turn the key to the ON position, marked by “II” on the ignition bezel so the dash lights come on.
- Listen for a quiet click, and then within 5 seconds press the “Lock” button on the remote for 1 second.
- Turn the key to the OFF position, marked by “I” on the ignition bezel so the dash lights go off. If you hear a quiet click in the dashboard after turning switch to "I" then the entire process must be restarted.
- Repeat three more times (for a total of 4 times).
- Upon the 4th turning of the key to “ON”, press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
- Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.
- Turn ignition completely off and remove the key.
- Step out of car and close door. The remotes should be programmed and work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will “pop”.
[edit] Tips
- You must wait for the slight clicking sound in the dash before you press the lock button on the remote.
- After you reprogramming if the Unlock button doesn't work,you must Unlink memory seat by pressing same time unlock and lock button pointed to receiver.(this for TL key fob)
tman570
06-11-2019 07:56 AM
Skirmich
09-15-2015 06:41 PM
asahrts
09-04-2015 05:55 PM
