Need help on a turbo setup asap
Old Oct 8, 2008 | 09:47 PM
cb717cls's Avatar
03 Boosted CLS
i have a j32a2 motor. I'm trying to figure out if i can tap the oil pan for the oil line going into the turbo and will there be enough pressure for it? if not where can i tap to put the line?
Old Oct 8, 2008 | 10:11 PM
artbran's Avatar
666 Speed
Wait, so are you trying to get oil to the turbo or from the turbo?
If to the turbo, buy an oil filter spacer thing that has a few ports to it. If you are draining oil from the turbo, tap the oil pan with a fitting...
Old Oct 8, 2008 | 10:20 PM
cb717cls's Avatar
03 Boosted CLS
well i got the fitting hole for the turbo dump of oil just need it oil to the turbo. do you know where i can get a good spacer from? i also need to figure out where all the other hoses go if you would know that too.. like exact points for the vacuum's, coolant lines, and fuel regulator setup. thanks
Old Oct 9, 2008 | 07:36 AM
smokendsm's Avatar
ridin slow'n'low
wow..../facepalm
Old Oct 9, 2008 | 08:43 AM
cb717cls's Avatar
03 Boosted CLS
Originally Posted by smokendsm
wow..../facepalm
wanna make sure how i figure it goes on will be right dont want anything to go wrong. I figure do it right the first time i wont have to fix anything that messes up by it being done wrong. found the filter spacer by the way.
Jul 16, 2017 07:33 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
joflewbyu2
Oct 8, 2015 11:16 AM
dirleton
Sep 25, 2015 12:25 AM
