Need help on a turbo setup asap
03 Boosted CLS
i have a j32a2 motor. I'm trying to figure out if i can tap the oil pan for the oil line going into the turbo and will there be enough pressure for it? if not where can i tap to put the line?
666 Speed
1 Post
Wait, so are you trying to get oil to the turbo or from the turbo?
If to the turbo, buy an oil filter spacer thing that has a few ports to it. If you are draining oil from the turbo, tap the oil pan with a fitting...
03 Boosted CLS
well i got the fitting hole for the turbo dump of oil just need it oil to the turbo. do you know where i can get a good spacer from? i also need to figure out where all the other hoses go if you would know that too.. like exact points for the vacuum's, coolant lines, and fuel regulator setup. thanks
joflewbyu2
10-08-2015 11:16 AM
