low gas effect on our cars
am I the only dummy that drives around with my gas light on all the time would any of you guys be able to tell me exactly how bad this is for tha CL??
thanks.
thanks.
In the Mid-South meow
I think the only issue you'll really take a chance on having when doing this is possibly picking up settled particles that sit at the bottom of your tank. Other than that I don't really see anything bad about it.
I don't see any danger of anything on the CL/TL. The filter is in the tank attached directly to the pump. Nothing is getting through that without some serious problem arising, & by that time you will notice it.
I run the car till the light comes on then get gas. That's what the point of the low fuel light is.
The whole crap at the bottom of the tank thing is a problem that no longer should be of any concern within that last 15 years. Gas has gotten better, gas tank are plastic, & fuel systems are much improved & cleaner.
Originally Posted by Acutron
I run that mo fo till it cries for gas (via low gas light) all the time. I would run out of gas if it werent for that indicator...........
Ive been running mine to the low fuel light for the last 225k miles now with no issue
eh, the gas intake is at the bottom of the tank anyways, as stated. I also go by the fact of if i run it low every time, your not allowing too much sediment to build up. I just know that i have 3 gallons of gas once the gas light turns on, and plan accordingly.
