Loud clicking noise when temp dial turned
Old Oct 1, 2018 | 09:50 PM
nishant11's Avatar
My 02 CL-S did not have heat so I changed water valve. Now heat is fine but when I turn temperature dial to Max AC , I hear loud clicking noise for about 30 seconds from under dash on passenger side
The noise goes away if
a) I turn the temp dial beyond half way or to full hot
b) Do nothing and wait for 30 seconds when it stops but comes back again with ignition cycling
I checked movement of water valve lever to which actuating cable is attached. It looks fine.
I hope nothing breaks with loud clicking noise.
Any advise?
Old Oct 2, 2018 | 06:07 AM
Iggy's Avatar
Most likely air mix motor assembly. Here's the DIY https://acurazine.com/forums/second-...repair-848488/
werehm
Feb 23, 2012 06:36 AM
gth181a
Oct 8, 2009 12:29 PM
elkayem
Nov 24, 2007 05:14 AM
TxTLtypeS
Aug 9, 2004 07:41 AM
