kick when I start the engine
Old Mar 11, 2013 | 02:20 PM
drive21's Avatar
7th Gear
Long time I'm trying to find the problem created me and I can not figure it out .
It all started after I changed the gear oil immediately after the exchange was a sense of kick when I start the engine .
I drive like that almost a year .
I recently replaced gear oil again it got a little better, but still have this problem
Mainly it existing when the engine is cold, when the engine is hot every thing all right .
I replaced almost everything .
I know the gear mount is ok .
the gear is great .
Now I can only think about it maybe one of the 3 engine mount how I can know which one ? the are all look for me fine .
the car work great after the engine start
is there any one had this problem ?
thank you for you help I really need one
Old Mar 11, 2013 | 05:13 PM
gnuts's Avatar
3.5 psi
do you mean you replaced the transmission fluid?
Sounds like broken motor mounts. They crack and can leak black fluid. Have someone rev the engine high and see how much the engine moves.
Old Mar 12, 2013 | 02:42 AM
drive21's Avatar
7th Gear
yes i mean i replaced the transmission fluid .
all the mount seems ok no fluid leak .
i will try rev the engine high and i will see
i think to its one of the mount to i wish i know which one i try what you suggest .
Old Mar 12, 2013 | 10:56 AM
gnuts's Avatar
3.5 psi
how many miles on your car? the rear mount is probably gone. But might as well replace them all.
Old Mar 12, 2013 | 01:51 PM
drive21's Avatar
7th Gear
56300 miles .
yes, i think i do that replace all off them .
thank you for your help
and confident for finding the problem
Old Mar 12, 2013 | 09:30 PM
gnuts's Avatar
3.5 psi
that's low miles wow! If you punch the car do you get the same kick?
Old Mar 13, 2013 | 02:27 AM
drive21's Avatar
7th Gear
what do you mean "punch the car " ?
so maybe i will replace only the rear mount ?
Old Mar 13, 2013 | 02:43 AM
drive21's Avatar
7th Gear
do you think maybe i try to change only the rear one ?
and if so is this ok ?
http://www.amazon.com/03-07-Engine-5.../dp/B004367PT6
or better to buy honda ?
Thank you
Old Mar 13, 2013 | 10:31 AM
byRatify's Avatar
That won't fit the CL.
Old Mar 13, 2013 | 10:53 AM
gnuts's Avatar
3.5 psi
I Mean If You Floor It. The Car Should Downshift And If Your Mounts Are Gone You Might Get That Same Kick Feeling.
Old Mar 13, 2013 | 12:29 PM
drive21's Avatar
7th Gear
yes sometimes .
can you give a link for rear mount ?
Old Mar 13, 2013 | 01:32 PM
drive21's Avatar
7th Gear
my accord is 2006 cl7
and this mount is correct
Old Mar 13, 2013 | 11:08 PM
byRatify's Avatar
Oh, well you never said what car you had..
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
MikeYutkin
Sep 10, 2015 10:13 PM
NSolace
Sep 3, 2015 08:14 PM
