Installing Main fuel relay
Old Jul 10, 2009 | 06:14 PM
Skims989's Avatar
6th Gear
Hi I am a newbie who needs to install a main fuel relay. I'm going to get the part tommorrow and know where the the part is located in the car , but just cluess from there. I would really appreciated if anyone can give me instructions or pointers on installing it...Thanks
Old Jul 10, 2009 | 06:17 PM
Skims989's Avatar
6th Gear
btw I have a 2003 CL-S
Old Jul 10, 2009 | 06:50 PM
disgruntlednut's Avatar
01 Type-S, Sexy Silver
The relay is located under your dash up by the steering column (the side closer to the driver door). There's a bracket that holds it up there. It's alot easier to remove the bracket itself rather than trying to remove the relay from the bracket. Just unplug the old relay and plug the new one in. Props to you if you can manage to get the bracket bolted back into place... if not, zip-ties are your friends.
Another option is to open up your relay and lookat the soldier points on the circuit board under a magnifying glass. You'll find some hairline cracks in some of them. Re-soldier them and plug it back in. It could save you $60 for a new relay.
see: https://acurazine.com/forums/showthr...ght=fuel+relay
Old Jul 11, 2009 | 12:19 PM
Skims989's Avatar
6th Gear
Hey man thanks for all the help ...got a new one plugged in and works like a charm....btw ...couldn't get the old plastic cover off the metal bracket...any ideas...once again thanks...
Old Jul 13, 2009 | 09:11 AM
hermtm2's Avatar
If you got the new relay, it just hammer it.
Or if you want to fix it, the gray plastic box will be open by a small flat head driver.
Thanks.
Old Jul 14, 2009 | 09:02 PM
Yea, its a pain to get it off the bracket, just gotta work it out with a flathead screwdriver. Imagine trying to get it off upside down under your dash...
Old Jul 17, 2009 | 12:45 AM
superfob's Avatar
The bracket itself isn't very expensive. I think I paid $2-3 at the dealer.
Feb 25, 2020 09:57 AM
Skirmich
Sep 15, 2015 06:41 PM
PortlandRL
Sep 14, 2015 12:01 PM
NSolace
Sep 3, 2015 08:14 PM
