Hesitation problem
Old Feb 5, 2020 | 08:36 AM
Soseductivesf's Avatar
Hesitation problem
Alright guys I have an issue I can’t seem to figure out and hopefully I can get some good advice. This is for my j35 2003 CLS6. I get this hesitation when driven cold. I also get a random hesitation from 1st-2nd(only at WOT) and sometimes when I park the car for 5-15 minutes when I 1st drive it it hesitates and sputters for 30 seconds then drives fine.
Things I changed. Rebuilt J35a3, new clutch & flywheel, recently rebuilt transmission, rebuilt & ported heads, rebuilt injectors, new oem coilpacks & sparkplugs, new walbro fuel pump, runners, manifold & throttle freshly ported & polished, new map, throttle position, intake air, coolant temperature, crank position sensors, used low mile fuel pressure regulator, new fuel return line hose, added a ground wire
This happened with my j32 engine as well
Old Feb 25, 2020 | 01:55 PM
Acura2g558's Avatar
Is your TPS calibrated correctly and did you use aftermarket MAP or TPS? Check your timing and lastly, check for exhaust obstructions like a clogged cat.
Old Mar 4, 2020 | 08:29 AM
tps is oem and calibrated to 9.4. Timing was checked and I have a test pipe
Old Mar 4, 2020 | 08:39 AM
Acura2g558's Avatar
Sounds like you need to run some diagnosis on your spark, air and fuel to make sure that you're getting the correct and expected values according to OEM specs. You've got a lot of aftermarket parts going on, my suspicion is that something isn't reporting correctly or that you have a faulting part. It's going to take a some instrument diagnosing to determine. A PicoScope is probably your best bet to find out.
Old Nov 3, 2020 | 07:01 AM
Problem fixed. The engine ground wire wasn’t in the right place
Old Dec 8, 2020 | 08:49 PM
One_Good_Knee's Avatar
4th Gear
where is that ground wire located I need to check mine because my 01 cl is doing the same this it hesitates to accelerate here and there and it happened when I changed my valve covers and what not happened a day after so not sure if I touched something no misfire codes no cel no vsa nothing no lights on and iacv throttle body was changed along with fuel pump and main fuel relay that’s located under the dash and that still didn’t fix my problem when I drive the car to a store leave it off and 15 minutes later I come back and the car turns off then dies I have to keep my foot on the gas to keep it alive then it doesn’t die someone recommended I change the 3 sensors one behind the intake plenum the fan switch and coolant sensor in order to get rid of that I also used sea foam to clean the fuel injectors and nothing
Elderstarr
Apr 22, 2017 11:09 AM
richardparker
Oct 8, 2013 12:12 AM
BlackV62K2
Jun 15, 2007 06:04 PM
Sly Raskal
Apr 5, 2007 04:14 PM
97CLgenius
1G CL Problems & Fixes
Sep 9, 2006 09:05 PM
