Help headlight out, yes I searched !
Old Jun 19, 2010 | 01:36 PM
sayfulhaqq's Avatar
Greetings Azine:
Seem to be running into more problems with the CL. My passenger headlight burnt out. I replaced the bulb 5 months ago, and it went out, driver side is running perfectly.
Swapped the bulbs out, no good. Saw the low beam fuse was burnt out. Replaced it , burnt out again.
Searching around it seems like its a ballast issue, I just want to confirm that this is indeed the problem.
If so, have you guys just been buying OEM ballasts and replacing. I see several people here are buying aftermarket kits.
Should I also replace the ballast in pairs?
Thanks!
Old Jun 22, 2010 | 09:32 AM
sayfulhaqq's Avatar
43 views, no one knows, is it that I need a new ballast, I'm pretty sure it is, I just want to confirm , thanks!
Old Jun 22, 2010 | 09:28 PM
Seymore Cake's Avatar
'01 Acura CL Type-S
As Captian Planet would say "Only You Have the Power"
Just replace the ballast or just take it to a shop and have them check it for like $50
Old Jun 23, 2010 | 10:26 AM
sayfulhaqq's Avatar
Thanks for the reply, but I refuse to take it to a shop, I have a better chance of asking here. I realize I can just replace the ballast, but before I go buy and spend money I want to be 100 % sure.
Tried 2 different bulbs on the blown side, and 2 fuses blowing , pretty sure its a ballast.
Debating of going the aftermarket kit, I just want the headlight to work so I can see at night again, lol.
Anyone....
Old Jun 23, 2010 | 11:00 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
If you keep blowing fuses it's most likely the ballast.
You can tell if you switch the whole head lamp to the other side and plug it in.
The working ballast will work on the other side.
And the bad ballast will blow the fuse on the other side.
very easy
Old Jul 10, 2010 | 04:46 PM
sayfulhaqq's Avatar
Well I thought would give an update:
ITS FIXED!!!!
Put a new ballast in , problem solved , I have working headlights again!
Thanks again for everybody replies.
Old Jul 14, 2010 | 03:04 PM
ed peters's Avatar
3rd Gear
ITS FIXED!!!!
Where did you get the new ballast? tks. Ed
IBankMouse
Jun 13, 2020 12:53 PM
Jul 16, 2017 07:33 AM
rockyboy
Sep 29, 2015 12:05 AM
AmplifiedDetails
Sep 24, 2015 02:55 PM
