Help! Cl starts then dies out
I fill up with gas not top or antyhing just half way, I start the car it dies out, I start again it doesnt start, and then I keep trying finally it starts.. No check engine light, drives fine and all.. What could be causing this problem, it did it this morning when i was leaving for work as well. But then it started drives fine and idles fine. I dont know what the problem could be please help!
If this is happening only after fill up - Check EGR valve - under hood, drivers side, by strut tower you will see purge valve and lines going down the firewall. Look for a green cap - you need to check the valve on that line. Just remove it and blow through it. If it is stuck open it is faulty
