Headlights are WAY too low
When we first got the car they seemed low enough, so we had the dealer realign em to stock specifications. Well it seems some idiot must have aligned it with the lowest part possible, they are so damn low its the lowest part of the high beams that shines where the highest part of the low beams should be at. I tried looking everywhere on how to adjust them but no luck so here I am. HELP
Behind each of the headlight housings are 2 gear-like mechanizm's, one is for up & down, one is for left & right.......use a phillips head screwdriver, and be sure that your car is parked on level ground & facing a solid wall, open the hood & turn on the lights and adjust the beams (the low-beams should be no higher than the top part of other cars rear bumper / bottom of trunk). I hope this helps.....
blacktsxwagon
Oct 27, 2015 10:12 PM
