headlight problems
Old Apr 14, 2006 | 05:41 PM
i3aog's Avatar
headlight problems
my passenger side headlight is acting up....when i first turn on the headlights it flickers a few times....but other than that it stays off all other times.....does anyone know why, do i just need a new HID bulb?
Old Apr 15, 2006 | 05:01 PM
phipark's Avatar
Not Asian
Sounds like it's not the bulb. Maybe the inverter.
Old Apr 16, 2006 | 11:02 PM
gsrblack's Avatar
mine did that the first time it went out....dealer replaced bulb and inverter under warranty
just had the headlight go out again (2 years) and dealer replaced bulb and inverter again.
Old Apr 17, 2006 | 06:41 AM
i3aog's Avatar
thanks guys, well just had the bulb replaced, works fine now, just need to figure out how to adjutst the bulb to make it point higher, but yeah turns out it was the bulb
Old Apr 17, 2006 | 08:15 PM
Stealth CL's Avatar
proffesion...axle breaker
hold up a min....mines startin to act up. the passenger side too. it will turn on fine. but on occasion...(just sometimes) after like 10 minutes or soo it will go out...but if i flick them off, and then back on, it works fine...whats up with that? is it wearing out, or just getting too hot?
Old Apr 18, 2006 | 11:07 PM
i3aog's Avatar
hmm that i dont kno about, mine when i initially turn on the lights, it flickers for like .5 seconds and then stays off so i naturally thought it was the bulb, which it turned out to be so.......an idea to test it out....take the bulb from the driver side and put it in the passenger side and see if it works....that'll tell u at least if its the bulb or a bigger problem
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
