Hard STart after Refueling
has anyone with a 01-03 cl experienced this problem with starting after refueling?
i've read other problems with people starting and resoldering/replacing a fuel relay...has this worked for this scenerio?
any feedback is well appreciated becuase i can only get my car to start after turning the key 3 or 4 times
it mostly happens when i refuel but will happen intermittenly between refueling.
i have tried leaving the key in the "on" position to get it started again when it fails....it usually starts back up if not after 4 or 5 tries.
This is really iritating though...could it be the fuel relay? What do you think could be the problem here?
Giant Blue Car
I would check the fuel relay first then:
If you don't have a multimeter:
Besides the PGM-FI being the culprit, I'd also check your fuel filter, fuel pressure regulator, and ignition coils.
- Check the ACG (S) 15A fuse under the hood to see if it's blown;
- If it's ok, check the No 1 15A fuel pump fuse underneath the dashboard on the driver's side.
snorf
11-04-2019 06:44 AM
