Gauge Cluster Bulb problem
Old May 29, 2011 | 08:39 PM
SimonCL-S6's Avatar
Alright sorry if this is a repost but i couldnt find the answers im looking for when i searched. So i got out of work not too long ago and when i turned on my lights i noticed that the 8 and the 9 on the RPM gauge are out... i have a few questions. 1. Why is it only affecting that small area? 2. How much would the dealer want to fix this, or am i better off doing it myself? 3. Is it the bulb or can it be something else? 4. If it is the bulb, should i just replace them all so that they dont randomly go off like this one?.... THANKS IN ADVANCE!!!
Old May 29, 2011 | 11:42 PM
civicdrivr's Avatar
Its just the bulb in that area. You can get a replacement bulb and install it yourself.
Old May 30, 2011 | 01:45 AM
SimonCL-S6's Avatar
Do you know the part number or a DIY on this...
Old May 30, 2011 | 01:58 AM
civicdrivr's Avatar
I believe youre looking for PN 35505-SJ4-003
I dont have a DIY, but its simple. Remove the dash trim, remove the cluster, and swap the bulb from the rear of the cluster.
Old May 30, 2011 | 11:40 AM
SimonCL-S6's Avatar
Alright thanks alot man!
Old May 30, 2011 | 11:45 AM
Karanx7's Avatar
Unregistered Member
Can you do me a favor and check something? When you turn your headlight switch from OFF to Middle, does your Odometer change brightness? How about from Middle to ON?
My odometer doesn't change brightness anymore, and I think it is supposed to. Just wanted to check. Thanks.
Also, it's a really easy job to change out that bulb. If you need help taking out the cluster, I can post the service manual pics.
Old May 30, 2011 | 11:51 AM
SimonCL-S6's Avatar
I dont think its supposed to change brightness i never noticed that. Right now its way too sunny to check so i will post here later tonight and let you know.
Old May 30, 2011 | 04:29 PM
aznboi2424's Avatar
If you turn on your parking or headlights, all of the guage lights and dash lights will turn on. If they dont, check the dimmer switch.
Old May 30, 2011 | 04:49 PM
Karanx7's Avatar
Unregistered Member
Thanks, I'll be waiting
Yea, but the Odometer uses a different set of bulbs. I've gotten mixed reports about it.
Old May 30, 2011 | 05:14 PM
aznboi2424's Avatar
They use different bulbs but they are all connected to the dimmer switch and they all turn on when the light stalk is turned.
Old May 30, 2011 | 05:25 PM
Karanx7's Avatar
Unregistered Member
No it's not. The odometer bulbs light up even when the speedo bulbs are off.
I've seen a video of the Odometer bulbs changing brightness when the headlight switch is activated. Someone on the TL side has also confirmed this.
I've also seen a video of the Odometer bulbs NOT changing brightness when the headlight switch is activated. My car doesn't change brightness.
I think my car used to change brightness also, but wasn't sure. I think that if you have never removed your cluster, then it will change the brightness. If you have messed with it, then it probably won't.
I'm just trying to understand the discrepancy.
Old May 30, 2011 | 05:31 PM
Karanx7's Avatar
Unregistered Member
http://www.youtube.com/watch?v=6y55Hsz9oBA
STOCK cluster with odometer bulbs that change brightness when the headlights are activated. Skip to 1:30. (It's still kind of hard to see)
http://www.youtube.com/watch?v=DJZ-6xGSluk
MODDED cluster with odometer bulbs that do NOT change brightness when the headlights are activated.
My cluster has been modded with LEDs, and the odometer does NOT change brightness.
Here is a thread in which a member confirms that the bulbs DO change brightness:
https://acurazine.com/forums/2g-tl-1999-2003-98/odo-bulbs-816905/
Old May 30, 2011 | 06:07 PM
civicdrivr's Avatar
Im running LEDs in my cluster as well, and my odometer does change brightness with the other bulbs.
Old May 30, 2011 | 06:19 PM
aznboi2424's Avatar
Well i do know that just the letters are lit up when the switch is off. When the switch is on, they are dimmer but the other lights go on too.
Old May 30, 2011 | 06:31 PM
Karanx7's Avatar
Unregistered Member
FUUUU... Now I'll have to figure out why my LED odo bulbs aren't changine brightness ='[
Old May 30, 2011 | 06:34 PM
civicdrivr's Avatar
Ill double check though, I think I may have misunderstood you.
You want to see if the bulbs change brightness when you turn the lights on? Or when you adjust the brightness with the brightness control switch? I dont remember if they change when you turn the lights on. I think theyre at full brightness when the headlights are off then whatever you have the brightness set to when the headlights are on. I think.
Old May 30, 2011 | 10:24 PM
civicdrivr's Avatar
Karanx - My camera didnt pick up the colors that well, but you can see the odometer stays at full brightness when the headlights are off.
http://www.youtube.com/watch?v=Vh9V6lEOb8w
When the lights get dim, I was using the dimmer switch.
Old May 31, 2011 | 03:29 PM
Karanx7's Avatar
Unregistered Member
OMG civicdrivr(what's your real name?), I owe you big for that video. Now I understand how it works.
The odo bulbs go:
Light switch Off -> Light switch ON
Max brightness -> Brightness set by dimmer
Before I put LEDs in my cluster, the odo brightness would change from "light off" to "light on". After my install I set the dimmer switch to Max, so the brightness didn't change when I changed the switch. If you keep the dimmer switch to medium, then ODO bulbs will change when turning on the lights.
Silly me, I thought I messed up the wiring or something lol. Thanks a lot for the video. Really cleared things up.
Old May 31, 2011 | 03:43 PM
civicdrivr's Avatar
NP.
-Morgan
HairyMonkey019
Apr 22, 2016 10:50 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Sep 17, 2015 10:16 AM
brandnewcolony
Sep 12, 2015 10:39 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
