F-ing headlights!!!!!
Old Nov 14, 2008 | 10:01 AM
micgrojas's Avatar
I have a 2001 Acura CL-S and the right headlight went out last night. first it was really dim and then it eventually went out. the left one is starting to flicker and i cant lose both of them. I havent checked the fuse so ill do that tomorrow..any suggestions before i have to blow money on godamn headlights?
Old Nov 14, 2008 | 10:28 AM
micgrojas's Avatar
forgot to mention
they are H.I.D's...help!!
Old Nov 14, 2008 | 01:38 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
probably have to buy new ballasts unfortunately. but i would test with someone else's bulbs first.
Old Nov 14, 2008 | 02:17 PM
GRNMCHN03cl's Avatar
Oh come on it's an excuse to get some 10,000 k's
Old Nov 14, 2008 | 03:09 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
yes cause 10000k is so cool.
Old Nov 14, 2008 | 09:37 PM
Says the guy who put black caliper paint as a mod in his sig.
Rotora slotted rotors|H2 Ceramic Pads|Legend Coupe front calipers|Black caliper paint|XS headers|M5 lip spoiler|Yokohama Ice Guard IG20|Tokico HP Shocks|H&R Sport 51858|Corsport shifter cable bushings|CDD bypass|Techna-fit SS clutch line|UR underdrive crank pulley|Innovative poly engine mounts|Progress TL rear sway bar|Energy sway bushings|MOOG swaybar endlinks|NEUSPEED short shift|TL-S shift knob|TL rear console vents| Hella micro de fogs,TL fog switch|HIR hi-beam conversion|Homelink mod
Old Nov 17, 2008 | 04:47 PM
disgruntlednut's Avatar
01 Type-S, Sexy Silver
Old Nov 18, 2008 | 07:15 PM
timrink's Avatar
You can test your headlights at an Acura dealership, if you're close to one. If your headlight doesn't light up in the Acura tester, it's probably your ballast.
If it's your ballast, it's going to cost you. They're $420 each from the dealership. Check out my other post on this issue for directions on how to change the ballast.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
