exhaust help
Old Nov 2, 2006 | 03:07 PM
PANAMARED's Avatar
exhaust help
Hello, hope somebody can help me out.
The exhaust system of my 2001 CL 3.2 type S was removed from under the engine. There are no exhaust regulationsin my country (Panama). Can I eliminate the use of cat converter and the rear oxygen sensor (after cat)?. If so, will that send problem codes to the ECM?
Old Nov 4, 2006 | 02:40 AM
vinceyang369's Avatar
more than likely you're check engine light will kick on. I had a friend who gutted out his cat and the check engine light kicked on. No problems though.
Old Nov 7, 2006 | 11:26 AM
PANAMARED's Avatar
Thanks for your helpfull comment... don't you think that an error signal from the ECM (a wrong oxygen reading) will trigger a bad mixture ratio or idle speed? Maybe the ECM can be configured someway to avoid this? I really will appreciate any help tht I can get. Thanks again!
joflewbyu2
Oct 8, 2015 11:16 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
ivan06106
Sep 26, 2015 04:38 PM
