Everyone with random misfire codes!!!read me!!
Old Dec 14, 2010 | 10:58 PM
rear turbo cls6's Avatar
Hey peeps I was doing some research because I have checked everything and my car is still misfiring in lower gears during hard accelerating. I ran across this! hope it helps. http://ww2.justanswer.com/uploads/th...01_misfire.pdf
Old Dec 15, 2010 | 09:21 AM
fuzzy02CLS's Avatar
Very interesting....
When owners of ’00–03 3.2TLs, ’01–03 3.2CLs, and
’01–02 MDXs complain about the engine running
rough between 40 and 70 mph, are you finding
misfire DTCs (P0301 thru P0306, P1399, P0133)
set? The problem could be clogged EGR ports or
an upside-down intake manifold upper cover
gasket. Since the EGR ports aren’t symmetrical, an
upside-down gasket covers some of the ports,
creating uneven EGR distribution.
Old Dec 15, 2010 | 01:13 PM
civicdrivr's Avatar
There was a member from about a year ago that had that issue because of an incorrectly installed cover gasket.
Old Dec 26, 2010 | 03:58 PM
Jim99acura's Avatar
Dreaded P0301 -P0306...
Hey, I recently had the multiple mis-fire codes and read all the posts. I tried to get technical and take a resistance readings from each of the ignition coils. They all checked about the same... Next, while the car was running I disconnected each coil one at a time and found the bad one; there was no change in the engine when I disconnected that one, all others the idle changed. Of course it was I believe #1, the hardest one to get to (back passenger side). I purchased a new one and replace the suspected bad one and $44 later, reset the computer, all is well. Thanks to all the posts, you saved me $$$ Have a great New Year.
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
01CLOwner
Oct 9, 2015 01:07 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
ghuns
Sep 16, 2015 04:26 PM
