Dash lit up and car shaking
Old Apr 22, 2013 | 02:17 PM
Undisputed's Avatar
Hey fellas I've recently had a problem with my 01 Acura cl-s.The car was being driven when it started shaking and then my whole dash lit up.Drove the car home and turned it off.When I turned it back on it was idling like normal the only thing was my check engine light was still on.Anyone ever came across a problem like this?Any help would be appreciated. Car has 141000 miles by the way.
Old Apr 26, 2013 | 03:38 AM
Corrosion's Avatar
White as night.
Cruise over to Autozone. Pull that code and see what happened. It's free.
Old Apr 26, 2013 | 12:00 PM
DEPTLS's Avatar
Check for Misfires. Could be your Coilpacks or spark plugs.. Start your car... let it run.. and pull your coilpacks out one by one. and when you are pulling them the car may shake more once one is pulled. if you pull one and the car does not shake or the vibration of the motor do not change or get worse then you probably have found the culprit...
Old May 5, 2013 | 12:03 AM
Undisputed's Avatar
Thanks for the replys.As of right now my check engine light,srs, and vsa lights are constantly lit up on my dash.
Old May 6, 2013 | 07:42 PM
aznboi2424's Avatar
Pull the CEL code with a code reader and we can start from there.
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
handsom-hustla
Nov 13, 2015 05:04 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
