2001 CL - Remote Programming Assistance
Old 04-11-2018, 02:44 PM
6th Gear
Ramey Becker's Avatar
Hello! I love this community and refer to it often. I am [almost] always able to find the answers to fix things myself – which is pretty cool!
I have a 2001 Acura CL and the remote key fob just died. I replaced the battery but it still isn't working. I've been attempting to reprogram the remote but seem to be having difficulty understanding the directions. I found the directions on another thread: https://acurazine.com/forums/second-...remote-514071/ .
1. Turn the IGNITION SWITCH ON. (note: this is the iii position, and you do not have to start your car)
2. Push the REMOTE LOCK BUTTON with remote aimed at the rec. In the passenger multiplex unit. (this is by the glove box).
3. Turn the IGNITION SWITCH OFF.
4. Turn the ignition switch on.
5. Push the remote unlock button while aimed at the rec. You should hear the locks click.
6. Push the remote lock button.
7. Within 10 sec. Aim the remotes (up to three) that you want to set at the rec. And press the lock or unlock buttons. When you do this each remote should be locking/unlocking the doors.
8. Turn off the ignition and remove the keys.
I am not sure which of the steps need to be done three times. I have tried a couple of combinations with no luck. It may be because I’m not understanding the “rec.” portion of the directions. Is this intended to mean receiver? If so, how do I know I’ve found it?
Finally, is there a light on the key fob supposed to light up? Maybe this is just plain dead?
Appreciate all assistance. Thanks!
Old 04-11-2018, 09:25 PM
Iggy's Avatar
Yes, there's an LED. Battery is probably dead. This is from the TL service manual but I imagine it's the same for the CL
Old 04-11-2018, 10:19 PM
frankjnjr's Avatar
("I am not sure which of the steps need to be done three times. I have tried a couple of combinations with no luck. It may be because I’m not understanding the “rec.” portion of the directions. Is this intended to mean receiver? If so, how do I know I’ve found it?")
("Finally, is there a light on the key fob supposed to light up? Maybe this is just plain dead?") The process is not as complicated as it appears! It's just that all steps MUST be performed in the proper sequence, within the allotted time. At least for me, it took several tries before I finally GOT IT RIGHT. Your question, " which of the steps need to be done three times" Answer, NONE.. I think you may be confusing "three times" with the system allowing up to three individual remotes to be programmed, to any one specific car. You are correct, in that the "rec." is being referred to as the receiver. If you point the remote, in the general direction of the glove box, you will have found it, as that is the area where the receiver is mounted. The remote need not be pointed exactly at the receiver, just in it's general direction. And, yes, there is a red led on the remote. If the led does not light up, when either the lock or unlock button is pushed, that would indicate, 1. The battery is dead. 2. The led itself is dead. 3. The remote itself has an issue. If you make several more attempts, and still cannot get it to work, I have a working remote that i can send you to try.
JSTSTEELERS
1/2G MDX (2001-2013)
01-27-2018 12:31 PM
NOVAwhiteTypeS
04-12-2007 07:31 AM
slappy12578
02-13-2004 07:01 PM
Rice02
01-16-2003 10:47 AM
Shawn S
02-14-2002 01:13 PM
Quick Reply: 2001 CL - Remote Programming Assistance
