Comptech Flywheels Breaking Crank Position Sensor
Old Aug 5, 2007 | 04:34 PM
type-s09's Avatar
13.2@ 107 on Street tires
I am posting this for my friend with an 03 CL 6 speed, he has I/H/E/P/S and comptech lightweight flywheel/clutch...hes doesnt drive all that much because he has a daily driver but after about 800 miles on his clutch/flywheel, it started breaking the magnet in the crankshaft position sensor...it only breaks it if he gets on it, he is on his third one...is there an explanation for this? he does have the UR pulley set, and ive heard the flywheel,pulley combo isnt good, is this the reason he is breaking sensors? He thinks its because the flywheel might not be torqued down to spec but im not sure, any suggestions?
Old Aug 5, 2007 | 04:53 PM
fuzzy02CLS's Avatar
The pulley seems to be the cause. However it's not been proven. Test it! Have your friend put the stock pullies back on & then the new sensor & see how it goes.
Old Aug 5, 2007 | 05:53 PM
type-s09's Avatar
just the crank pulley? or the whole set?
Old Aug 5, 2007 | 06:31 PM
fuzzy02CLS's Avatar
Crank
Old Aug 5, 2007 | 08:27 PM
SIRSIG's Avatar
THE J35A2...
not sure if he got the same problem tho but this helps to understand things a bit...
https://acurazine.com/forums/showthread.php?t=122775
https://acurazine.com/forums/showthread.php?t=109949
Old Aug 6, 2007 | 05:31 AM
ThinJim's Avatar
I had my comptech flywheel on for nearly 30k miles. 10k with supercharge, and another 20k with turbo and a few thou na. I had no problems whatsoever. The ur pully seems to aggravate the flywheel, I wouldn't use the aftermarket pulley with the lightweight flywheel.
Old Sep 21, 2007 | 08:07 PM
salcls's Avatar
http://img168.imageshack.
My crank sensor just blew out today! I was going home from work and this civic pulls up next to me at a stop. We both floor it to get ahead before the line merges, I was in second gear when I looked to see how far behind he was when I hit my rev limiter. When I switched to third the engine started choking at 2,000 rpm and my check engine light came on and so I had to pull over. Luckily my homie's shop was 3 blocks away. So he checks it turns out to be the sensor and tells me it could of been my Flywheel that fucked it. The sensor is $120 and it will be here monday morning, so no car for the weekend!
2003 CL-S 6 speed
aem cai
comptech headers/exhaust
comptech clutch/flywheel set
Unorthodox pulley set
front/back nrg dampers
Old Oct 31, 2007 | 08:54 PM
krisdlm's Avatar
Lives On BOOST
2003 CL-S 6 speed
aem cai
salcls, where did you get the crank sensor b/c i need one asap
Old Oct 31, 2007 | 11:03 PM
Accord_V6_400m's Avatar
4drs just wanna have fun!
The one in the tranny is like $80-$90. Either try a dealer or go to oemacuraparts.com
Old Nov 18, 2007 | 03:05 PM
type-s09's Avatar
yeah turns out its the pressure plate coming apart
Old Apr 2, 2008 | 10:31 PM
MurkyRiversTL's Avatar
COTM Coordinator
Ok Im having the same problem, but its not with an aftermarket pulley or flywheel. My cranks sensor is giving me codes and the car cuts out at 2000 rpm. Is this the crank sensor at the crank pulley/timing belt pulley, or the one on the tranny.
I hope to god its not the one by the cranks pulley, that thing is 500 bucks.
Also what could be the cause for this to happen.
Old Apr 2, 2008 | 11:28 PM
TCM 01 CL-S's Avatar
Uses turn signals in my
I can't help you with your issue, but don't worry if you have to replace the crank pulley, aftermarket aluminum is ~$175 and you can always pick up a used OEM one in the BM for like $30.
Old Apr 2, 2008 | 11:51 PM
Your timing is jacked up, I had the same problem when my timing belt skipped a tooth.
Old Apr 3, 2008 | 01:30 PM
COTM Coordinator
Well it wasnt my timing, or my flywheel or a broken magnet in the sensor
Here is my thread in the TL forums youll see what it was:
http://www.tl.acurazine.com/forums/s...d.php?t=177395
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
