code for 01 acura cl type s p1750
I have an 01 acura cl type s auto what is code p1750?
It's a hydraulic control system fault code. The possible causes are low transmission fluid or worse, failed hydraulic control unit. If your fluids are fine, the first curse of action is replacing the clutch solenoid valve, if the problem persists you will need to rebuild the transmission...which is exactly where I am right now :(
