Clockspring replacement 2001 acura cl
I need to replace the clock spring in my 2001 acura cl and a few weeks ago when i first started researching why nothing on the steering wheel worked i came across a post on here that gave the instruction on how to remove and reinstall the clock spring this post was from justnspace. Well now that I've got the new clock spring i can no longer finds that post. Could someone please help me with the step by step instructions? Thank you
This thread should have everything you need for the 'clockspring replacement':
https://acurazine.com/forums/third-g...spring-954604/
Should the thread above not be sufficent, all you have to do is go to the 'search' function above in the tool bar and type in your search terms and press enter. Scroll through the results, hopefully, to find what you need.
