car won't f#@king start!! daily driver...........
#42
Is it still working... the weather has gotten even hotter now...
I really had more problems since it has gotten hotter here in Houston esp on sundays because my car just sits out while we drive my wife's Suburban...
...I will be checking on this part's price tomorrow...
PS... its really hot here too.. abt 101 with the heat index!
#43
Almost a YEAR later... NO problems at all! Its such an easy DIY that I think the 20 bucks for the stuff to do it is great, plus I have used the good solder iron I bought a couple times since then... paid for its self few times over!
Thanks for the PM. I'll look at this thing ASAP and let y'all know what happens
#44
#45
It's supposed to be 93 today, but I'm parked in the shade so I might be okay. If not I'm bringing a can of compressed air with me when I leave to chill that thing down
#46
Haha, yeah I should have everything I need. I took a look at it last night but didn't have time to do the fix, so I'll probably do it tomorrow. Looks like taking the whole metal bracket off will be the easiest way to get it out since the actual relay is mounted to it pretty tight.
I waited because my sister's car was broke down, and I didn't want to not have a backup car if I accidentally messed mine up.
But anyways, the past 3 times it has done this I just used a can of compressed air and blew it directly onto the relay for a few seconds to cool it down. Not only does the car start right away, but it confirms that the relay is the problem.
Thanks again Rick for the help, I'll update if I have any more problems.
#48
And I guess I forgot to update this...haven't had any problems since!
All I did on the soldering was heat all the joints once and let them cool off again. I couldn't see any cracks in mine like Rick could, but at least one of them was still messed up so don't rely on just visually looking at it.
#49
Have you fixed it yet? Let us know if you need any help.
BTW... thanks for the update! Mine has been fine here during da HAWT Texas summer too...
#50
I will find the main relay under the steering wheel somewhere, right? Then just take it out, desolder, solder and put back in?
#51
Yeah, that's true Rick...if it does it again you can be sure I'll do a complete re-soldering.
Yep, just look for the relay with the numbers on it as mentioned before, near the brake pedal. Take the whole bracket off...you'll never get the relay off of the bracket laying under there...I believe a 10mm socket will get it. Take it apart and you'll see what to solder.
#52
Probably won't get to it until this weekend, but i will post my progress when im done!
#53
THANK YOU SO MUCH FOR POSTING THIS!! I have an '01 CL-S and your description matches mine completely!! I spent 103 including tax with the whole diagnostic thing and they couldn't find the problem. Googling it wasn't helpful either. Thank you and everyone who have contribute to this column. You guys made my day after reading all your posts.
#54
Thanks so very much! I am so glad that you are getting the benefit from this site... this is the whole reason I am here... the peeps here have helped me so much, its about time I could give back!
#55
#56
#57
Just wanted to show my appreciation for Acurazine and all it's grandness. Car hasn't been starting recently, and a quick search pops up over a dozen threads with several similar symptoms. I take out the main relay from under the dash, crack it open, resolder all points, replace, and the car starts up. Thanks. I've been on multiple auto forums, and none come close to the knowledgeable and competence of the people here.
#58
#59
I figured I'd do some resurrection...
I replaced the main relay, and now my keys aren't programmed to the car any more. The immobilizer light isn't flashing any more. Any one else experience this?
saberlove
03-11-2021 09:29 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
