Can someone tell what this light is?
The resetting you did (holding the trip buttons) resets the maintenance dummy light. You need an OBDII scanner to reset the CEl.
Go to AutoZone and have them read the code and post it here. The issue is not resetting the light, it's figuring out what's causing it.
That ligh is the CHECK ENGINE LIGHT. That is a bad thing when it comes on. You can reset a CEL with OBDII scanner only. Not with reset/select buttons. If that light is on is due to a malfunction. get it scan ASAP to get codes. It can be a multitude of things. Good Luck
Yeah, stupid me. for some reason I thought the maintenance light was the check engine light. Thanks for clearing that up. LOL, It end up being a knock sensor and sub-wire, which I replaced over this weekend.
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
