Can a bad main relay still click?
My son's '01 CL Type S won't start. It will crank over and seem to try to start almost immediately but will not fire and run. He told me the first time it did this (a couple of days ago) it finally started but ran crappy,but he got it home. I borrowed a code reader and it tossed an Oxygen Sensor code and we replaced it,but the car simply will not start - same as earlier. The starter will crank it over but no start. I read about relays here and called him and told him to turn the key from Off to On (not Start) and to listen for a double click under the dash. He tells me he heard the clicks. Does that rule out the Relay? If so anyone got any other suggestions where we should look?
Everything there is to know about your Honda/Acura main relay:
http://www.tegger.com/hondafaq/mainr....html#blueline
http://www.tegger.com/hondafaq/mainr...mainrelay.html
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
