Automatic AC problem
Old Aug 4, 2009 | 04:30 PM
generallee's Avatar
8th Gear
The temperature doesn't seem to hold consistent meaning if I set it at 70 it will blow cold then not not steady. Is their a sensor inside I should check and clean?
Any suggestions appreciated.
Lee
Old Aug 4, 2009 | 04:44 PM
aznboi2424's Avatar
that maybe normal. If you set it at 70 and the temp inside the cabin gets to 70, then the air will start warming up until it goes above 70.
Part of the AC system is the light sensor on the dashboard. it may blow colder when your facing the sun, but as you turn your car away from the sun and face shade, then the AC may blow warmer air.
as long as it feels like its 70 inside the cabin, then its doing its job.
rockyboy
Aug 4, 2024 10:35 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
Nizmosis
Oct 13, 2015 02:25 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
