Acceleration Issues
Old Feb 19, 2011 | 06:57 AM
TampaMille's Avatar
4th Gear
Acceleration Issues
2001 Acura 3.2CL
Hey all, I have searched this forum and others up and down for the answer to my issues to no avail. Here is the situation: I first got an O2 error code and replaced it. As soon as I did, I received an EGR code. So I pulled the top plate, and it was totally clogged, so I cleaned it and replaced the EGR, new gasket for both etc., etc. The car now has an intermitant accelleration issue. When you first depress the gas pedal, nothing happens, engine just stays at idle. no sputtering, then will all of a sudden shoot off like a bat outta hell. I am pulling my hair out as its not throwing any codes and nothing I do seems to work. Any ideas would be greatly appreciated.
Old Feb 19, 2011 | 06:58 AM
TampaMille's Avatar
4th Gear
Also, the car ran perfectly before I changed anything. So this issue is an after-the-fact issue that surfaced after the repairs I made due to codes appearing.
Old Feb 19, 2011 | 07:12 AM
TampaMille's Avatar
4th Gear
Another thing, this issue started after I installed the O2 sensor.
Old Feb 19, 2011 | 10:58 AM
nspec_ya4's Avatar
Regional Coordinator (Texas)
looks like ur TPS is not reading right. did you mess with that at all? 02 sensor has nothing to do with this acceleration problem. EGR, I cant really tell if that's causing this.
check for loose connectors, what ever you had disconnected.
Old Feb 19, 2011 | 03:35 PM
TampaMille's Avatar
4th Gear
I was thinking TPS as well, but I have disconnected and reconnected, made sure all connections were good. All is well. But still does it and its very dangerous having the car like this. Is the TPS adjustable on the 2001 3.2CL or replaceable?
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
carz0159
Sep 20, 2015 06:11 PM
NSolace
Sep 3, 2015 08:14 PM
