ABS system check going nuts
Old Apr 3, 2016 | 06:47 PM
toitle's Avatar
Hey guys,
This is the issue I am having. When I reverse out of anywhere it feels like my abs engages on the right front tire and the "!" light will blink rapidly. The only way I have found to temporary fix the problem is to turn the VSA off. Does anyone have any ideas for me?
Old Apr 18, 2016 | 12:59 PM
Tosh's Avatar
Eurotrash
Any diagnostic codes?
Fresh fluid all around, incl in the ABS reservoir?
Old Apr 20, 2016 | 11:08 PM
toitle's Avatar
No codes. Fluid is a little dirty. Also i find that when i back into a stall at a slow speed is when it will go engage the most. But as soon as i turn the vsa off it stops.
Old Apr 30, 2016 | 12:38 AM
YeuEmMaiMai's Avatar
you need to connect a data scanner that can read abs sensor data. If abs is always activating it means that (more often than not) one of the wheel sensors is bad. Reading the wheel sensor data stream will verify said problem.
Old Jul 26, 2016 | 02:24 PM
toitle's Avatar
Car will be hitting a scanner next week. Just had the engine light come on for what seems to be the torque converter. I guess i will have to wait and see if they pull anything.
gavriil
Apr 1, 2026 12:45 PM
gavriil
Oct 11, 2022 11:28 AM
TSX69
3G RLX (2013+)
1409
Aug 17, 2020 12:49 PM
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
Sep 17, 2018 07:45 PM
Chaotik
Apr 2, 2016 05:31 PM
