2003 Driver Side Window stopped working
Ive got an 03 CL that the diver side power window stopped working on. I looked on here & thought it was the motor/regulator which I got & replaced but it didnt fix the issue. The master switch on the drivers side will operate the passenger motor but nothing on the drivers side. Would the switch be the next thing to replace or am I missing something??? Any help would be great
Ok so I got a replacement driver side power window switch & replaced the original one but still not luck. The passenger side works fine but no movement or noise at all from the driver side. What am I missing??? I did check the fuses on each side of the dash but theyre all good too.
Ok so I just spent the last 2 hours taking both doors apart & trying to figure out whats up with the drivers window. I have 15 volts on the passenger side when the switch is activated but nothing on the drivers side. Im checking power at the connection for the window motor. Red/yellow & red/ blue on the drivers side & Blue & blue/black on the passenger side. Im wondering if the switch I bought was bad. Does anyone know what the wires coming from the switch are that correspond to each side. They arent the same as whats at the motor connection. This is really freakin frustrating
The following 5 users liked this post by hotclick56:
Bazla (04-04-2015),
Catfisha (11-05-2012),
jwbostic1980 (07-14-2020),
Oldsman71 (07-28-2013),
silo2323 (11-05-2012)
My car just developed the exact same problem yesterday. Have not done anything yet. Wondering what solution you eventually found. If its something I could do w/o removing door panel, that would be good to know.
Update: Motor and regulator are fine. Can run up and down with battery charger. There appears not to be any voltage to the 6 pin connector when I run the switch. It appears that wiring goes from master switch to a control module and then the motor. So the problem could be the switch or in the control module. Does anyone know which pins/wires coming out of the master switch should be hot when running the left (drivers side)switch? Both parts are pretty pricey and I don't want to buy something I don't need. Any test procedure or info would be helpful and appreciated. BTW I have checked all the fuses.
Update: Downloaded the TL service manual from Weezes link in another thread. Went through diagnostic procedures for the drivers side switch assembly (luckily wires were colored the same). Switch does what it is supposed to. This must mean its in the control module (I hope). Have ordered a new one and will see when its gets here if problem is solved.
Control Module fixed it. Thought there was another problem though, until I figured out the door panel connector that feeds the lights needs to be plugged in to provide power to the module. Weird wiring setup.
The following 2 users liked this post by hotclick56:
Bazla (04-04-2015),
Let me know if it's your motor that failed. I have an extra motor from my driver's side from when I replaced my regulator. I just have to look for it. Not sure if it fits tho.
Opened the passenger door and completed the window test. Window works. Tested switch and that works, so I reconnected the switch and that works. Driver's door works too. I did not find a problem so I will use it.
However I did learn that If it does not work I use the door courtesy lights for 12V to move the window up.
Rebirth of a thread....
I'm working on my driver's side window, a 2001 CL S-Type, and it appears I may have some different connectors/plugs.
On what I assume is the control module, I have a 20P connector and it also looks like for the power window connector, I have a 4P connector.
Is this just a difference between an '03 and an '01?
Or might I be looking at the wrong things?
Thanks.
Thanks.
Not sure if this is the right diagram because i can't till from your pic if the P4 actually have 4 wires or 2 wires. So confirm by matching the wire's colors.
Regardless, there is no "+12VDC" for the red/yel wire per say bc the polarity changes from pos to neg, depending on whether the window is moving up or down.
In the diagram to test the window motor simply supply both pos and neg power wires to the "red/blu" and the "red/yel".
Ie... hot to red/blu and neg to red/yel to test window movement. Then reverse polarity to move window in opposite direction.
The following 2 users liked this post by 01acls:
01CLOwner (11-03-2015),
It's got 4 wires.
I plugged in the control module and turned the car on so the windows had voltage to operate. The voltage at the red/blu and red/yel wires (output from the control module) read either +11.88 or -11.88, depending on whether I was trying to move the window up or down. It appears from this that the control module is functioning, unless I need to consider a possible load from the motor(?)
It looks like I have a bad motor, any other concurrence?
Thanks for the diagram acls.
It's got 4 wires.
Since you are already at the door with everything in front of you, I would test the motor too bc that is confirming the work.
It's best to confirm the work bc we all know that assumption is the mother of all F-U.
Plus you don't want to order a replacement part based on an assumption when you can easily make a positive confirmation whether is yea or nay.
Was finally able to get back to the window, had to get into Grandpa mode for the first time last week, a new grandson.
I installed a couple connectors onto the motor plug wires and added the 12 volts, changing polarity. Nothing happened, just a click or two, no movement up or down.
Anyone have a link to a decent power window motor repair video online?
Thanks.
Thanks.
metoymi (03-30-2016)
Finally got back to the window.
I went the quicker route and just bought a new one off of Amazon, $60 delivered. I found a video on removal/installation which was helpful.
I got the old part out and the new one in, took maybe 15 minutes, not including the door panel removal.
The window works now.
Thanks for the help guys.
