2003 Acura cl Rear window Defogger Doesnt Work
Old 10-31-2011, 11:27 PM
Ecnalb1028's Avatar
Hey I have a 2003 acura cl type S without navi that i recently purchase and the rear window defogger is not working. When I depress the rear window defogger switch it illuminates stays on for about 25 min then shuts off as the manual states. However, it does not defog the rear window. Is there any particular test that I can perform to locate the root cause of the malfunction? Does anyone have a detail schematic of the defogger circuitry and parts involve in its' functioning so that I can individually test each component. Wheres the wire that brings current to rear defogger hidden at?
All the electrical conducted painted lines seems to be intact. The previous owner state he had to remove the back console to tint the back glass but he also state that it was working afterwards. So I suspected a wire may be disconnected.....ANY HELP / SUGGESTION WOULD BE GREATLY WELCOMED AND APPRECIATED
PS
Where I live the car tends to fog easily so you can imagine my frustration.
Old 11-01-2011, 07:06 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,391 Likes on 4,937 Posts
There is a relay that could possibly be blown. When you hit the button, do you here a click from the dash area? If not, pick up a service manual and test the contacts on the window with a multimeter.
Old 11-01-2011, 10:51 PM
Ecnalb1028's Avatar
Well the only click that I hear is the actual defogger switch clicking when it is being turned on. Other than that no clicks. Besides do I have to remove the tints to test the connections??
Old 11-02-2011, 10:03 AM
civicdrivr's Avatar
Not, the connectors are raised off the window on the side.
If you dont hear a click, Im thinking the relay is bad. Mine clicks whenever I turn it on.
Old 11-02-2011, 11:33 AM
fuzzy02CLS's Avatar
I don't remember, but when I took my rear deck out I thought there was a electrical connector that connects to the leads from the defroster at the bottom of the rear window. If it's there maybe it's unplugged?
Old 11-04-2011, 05:42 PM
Ecnalb1028's Avatar
Well does anyone have schematics for the 2003 acura cl defogger setup. If you can point me in the right direction that would be awesome.
Old 11-07-2011, 07:36 PM
shrekloco's Avatar
Is the rear window tinted? If so that's where I'd start. I bet a razor cut through a connection on the window.
saberlove
03-11-2021 09:29 AM
handsom-hustla
11-13-2015 05:04 PM
HOWELLiNC
3G TL Photograph Gallery
24
10-08-2015 03:15 PM
dlknight
09-03-2015 07:54 PM
MyKids&Cars
09-01-2015 12:53 PM
Quick Reply: 2003 Acura cl Rear window Defogger Doesnt Work
