100k plus tune up
Old Apr 5, 2010 | 05:52 PM
jetrangr's Avatar
3rd Gear
100k plus tune up
*Any body have advise on ordering OEM parts from an acura dealer on-line?
* And is there only 1 timing belt to change and should I change the water pump at the same time I do the timing belt?
Thanks,
Lee
Old Apr 5, 2010 | 11:25 PM
aznboi2424's Avatar
I got my parts from kaleb (acurapartsguy) in santa rosa, ca.
If your just planning to do a simple 105k service then the minimum is timing belt, water pump, spark plugs, power steering and AC belts.
If you wanna do a complete 105k (costs nearly 1k) then i'll give you the parts on what you need.
Its also in your owners manual on what you need to service.
Old Apr 6, 2010 | 04:14 AM
jetrangr's Avatar
3rd Gear
Thanks. I've got the info on the 105k from the owners manual, just need to find the instructions on timing belt.
Lee
Old Apr 6, 2010 | 03:05 PM
brian6speed's Avatar
Lone Wolf
honapartsunlimited just emailed me with new discounts they are doing that is a higher percentage off based on how much you spend. Over 150 is 31% off retail, over 250 is 32% off, 500 is 33% etc. not sure if this is the cheapest tho.
Old Apr 6, 2010 | 03:15 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Hey Lee,
How about trying out our site vendors?
Old Apr 6, 2010 | 08:41 PM
hermtm2's Avatar
I've done the job a year ago. If you go to ebay, you will find so called "timing belt kit" which has a timing belt, water pump, serpatinbelts(AC, PS, AN), and tensioner. All parts were OEM or equivalent . The cost was around $ 300 including shipping.
Thanks.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
jmaxima03
Sep 27, 2015 10:22 AM
