'03 CL headlight ballast.
Old Jan 10, 2010 | 01:00 PM
Bowtied00's Avatar
I know I need a new ballast for the pass. side, and I know the frt. bumper cover has to be removed to get the headlight out. Is there a diagram out here that shows all that is involved in doing so? This is undoubtedly the most rediculous thing I have ever come across. Keep in mind I'm a Chevy/Harley guy, where things are a bit more straight forward. Sorry to all the Acura fans, No disrepect, but this is stupid, over 400.00 and half a days labor for a headlight out????? UNBELIEVEABLE!!!!
Old Jan 10, 2010 | 02:10 PM
civicdrivr's Avatar
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/cls-front-bumper-removal-diy-482462/
I do agree that it is quite rediculous that the ballasts are on the bottom of the headlight housing, and in an inaccessible area. That DIY is pretty good. Its really simple to remove.
Once you have the bumper off, you can remove the headlights. Dont forget to disconnect the ballast from the harness. I dremelled a slot into the screw holding the rear cover on. Remove the cover, push and twist to pull the ignitor out, unscrew the ballast from the housing, and gently pull it out.
The first time you pull the bumper off it may take alittle while. But overall it shouldnt take much longer then 1.5hrs.
Old Jan 11, 2010 | 09:03 AM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
theives can remover your headligts in 5 minutes/..
Old Jan 11, 2010 | 02:22 PM
civicdrivr's Avatar
They like to break shit.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
