'02 Heated Seat wiring
Old Nov 25, 2005 | 10:37 AM
e_fractal's Avatar
5th Gear
I bought a pair of leather heated seats from a 2002 CL-S. I'm hoping to find a pinout or wiring diagram before they're shipped to my door so I know what to expect.
Anybody know of any online recources or have a scan from a book?
Old Dec 22, 2005 | 07:54 PM
loud_whispers's Avatar
why would you need a wiring diagram?
Old Dec 23, 2005 | 03:20 AM
e_fractal's Avatar
5th Gear
Because theres 4 connecters, one with 15 wires alone.
They are airbag equiped so I would rather not test by trial and error with a power supply.
Old Dec 26, 2005 | 11:57 PM
e_fractal's Avatar
5th Gear
I tossed the PCB computer under the seats (black box) and wired the motors to my own relays.
I still need to know which wires go to the heating elements so I would appreciate if anyone has any info. My local dealer told me the information is not available to the general public
I know they have a High/Low/Off position switch in the dash. I'm guessing this went to the Black Box under the seats which reduced voltage from 12v for high to (??) low. Or maybe directly to the thermostat for temp control?
Old Dec 27, 2005 | 01:10 AM
e_fractal's Avatar
5th Gear
After looking at similar diagrams I have a good idea about what I need.
The switch in the dash has a resistor for both high and low, which feeds to the seat module. The module also has an an input for for the thermostat, to keep seats at the right temp. The module also applies correct amperage to the heating elements.
I need to know what ohm resitors are used in the switch and the pinout to use the module.
I guess I can take the upholstery off and try powering them with 12v and a 5A fuse and see what happens in the meantime. If I fry the elements Im going to try the aftermarket Carbon Fiber pads available now
If anyone could post a diagram I would very much appreciate it
Old Jan 11, 2006 | 01:12 PM
http://www.in.honda.com/Rjanisis/pub...103147000A.pdf
good luck
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
TL14
Sep 24, 2015 04:37 PM
