01 navigation code...
Old Nov 30, 2005 | 04:26 PM
chrisss's Avatar
saw the radio code post, any solutions on finiding the navigation code? just installed a new battery and i cant use my navigation without the default code.
i'm sad, please help, i dont want to deal with the dealer.
Old Nov 30, 2005 | 04:27 PM
kensukikatayo's Avatar
Turbo + Sound = Hey-pee
Yea it sucks, I had to pay for it...
Old Dec 22, 2005 | 07:51 PM
loud_whispers's Avatar
get me the serial number off of your navigation unit and i'll get you the code..
Old Dec 23, 2005 | 12:38 PM
chrisss's Avatar
will do, thanks! :-)
Old Dec 23, 2005 | 12:42 PM
brianlin87's Avatar
ASM I.S. Design FTW.
You had to PAY for the navigation code?
I've never had to pay for mine, just called the dealership with my VIN and memorized it for everytime I've had to unplug my battery.
Old Dec 27, 2005 | 04:05 PM
chrisss's Avatar
check your pm :-)
Old Jan 3, 2006 | 12:09 AM
OneFlyCL's Avatar
All i did was just checked the right side of my Glove box and there it is.....There should be a sticker with 4-6 numbers and that should work.
Old Jan 6, 2006 | 02:42 PM
Davidstingray's Avatar
Another thing to remember anytime you disconnect the battery. You must 1) reset the ECM and PCM and 2) do the idle memory reset proceedure.
Old Jan 15, 2006 | 12:35 PM
Hustleman1188's Avatar
Acura 2.2 CL Blue cutie
the only place u can go is ur dealer just go once aned ask for all the codes and write it down
Old Aug 21, 2006 | 09:14 AM
slowcl-s's Avatar
Senior Airman
Just curious how you do all that... Im new to my cl and havent herd about having to do that?
Old Sep 4, 2006 | 08:35 AM
speedB's Avatar
Easy
Radio serial code- 1) turn off radio 2)hold prestes 1 and 6 while turning on radio, it will flash an 8 digit serial number.
Navi serial code-
1) Crawl into your trunk on your back with you legs hanging out 2) use a flash light and read the code off the back of the unit- p.s. dont do this with any friends around that like to fuck with you, they will most likely close you in the trunk.
step 3 call service area with both, get both codes and write thm down in your manual.
dirleton
Aug 6, 2024 08:19 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
TLguy42
Sep 26, 2015 11:27 AM
