01 CL window won't go up and passenger seat won't move
Help!
Just purchased a 2001 CL Type S.
The passenger window was stuck in the down position when we bought it and it had been left open in the rain, so we needed to take the whole car apart to clean and dry it out.
We checked all the fuses and wires while the carpet was out and it has power to the plug ins. All checked out fine.
The passenger seat is also non-op. It is stuck forward. But it does have power to the seat where it plugs in.
What are we missing or what do we need replaced to get these to work?! We have no idea where to go or what to look at but figured this site would know! (you guys were able to help us take apart the car and put it back together smoothly!)
Help! and thank you
Help! and thank you
It's likely that you need a new window motor/regulator for your window. As far as the seat, that sounds like a separate issue. You're going to have to track down a bad wire if you're not getting power to the seat.
rockyboy
08-04-2024 10:35 AM
