01 Acura cl type s 83-01 ecm/pcm relation failure
Old Dec 1, 2017 | 02:38 PM
Jeddy Vic Fernandez's Avatar
I did the dumest thing when checking my calibration on my tps using a power probe to check the voltage I accidentally zapped 12v to the yellow wire that gives out 4.5v with it connect to the tps & ignition on. Will this fry my ecm/pcm cause it's in limp mode with the idle jumping 1k-700 rpm.. tried all the resets nothing..
make a appointment to the dealers but today I will try cleaning the ivac to help with the idle.. anyone out there has some know if I need just the ecm/pcm or all the sensors & units need to be replaced?
Old Dec 1, 2017 | 03:18 PM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a topic/technical issue which will require replies, and not a "New Member Introduction", I moved this thread to the model specific forum.
