Just Cleaned Her Up
Whats up with RDX owners?
Just Cleaned Her Up
Here are some shitty pictures. The last time I posted any pictures was when I first get the car in August, when it was bone stock:
Fast foward 7 months:
I've been keeping busy with it. Everything that is in my sig has been in the last 7 months. But I'm done for now since I have to focus my time and money on my other car. Maybe this winter I can finish her up.
You guys can give your opinion, but honestly, I don't give a f@$k
Its the Pioneer F90BT with the Acura start-up screen loaded onto it.
Only when I was up in NY last weekend and I hit a large bump. It was a very light rub. No marking on my tires or fenders, so it may have even been my rear sway bar that had a bolt loose.
I may still roll the fenders though.
Thanks for the positive comments!
PM me your email address. It is in widescreen format for the other larger screen AVICs though, so if you want full screen you could just chop the sides off, unless you have one of the other AVICs of course.
What do you mean similar setups? I contacted Uncald4 for the enclosure. He can make it for any sub. He made mine specifically for the sub I've got. If you go to the BM on here, he's got a thread in the sponsor forum.
Looks perfect!
What sub are you running?
I have a W3 and he recommended that one for his CL box.
Also...I have my amps mounted to that rear panel but did you reinforce it because there really isn't anything solid there.
I took some 1/4" mdf (1/2" so you don't have to double up like I did) and cut it to fit the area between the side panel and the pass through. Glued and stapled carpet, then screwed three of the four mounting screws for the amp on it. Then I attached it with some deck strapping. It's not going anywhere, it's very sturdy.
If you've installed radios before and you don't have a fear of wiring, nope. Thankyou.
NO CL FOR YOU!
Thanks for the compliment.
Spanks.
I do too.
Werd, my knob is the perfect size and weight, I have no problem slipping in between the gates
There's a few things that I have to finish up with them. I need to get the door switches converted to red still and try to get my sunroof switch to light up evenly. Right now it has hotspots.
I used to have blue LEDs but I didn't think it went well with what I was trying to do with the car.
I don't have the cajones to start a full LED swap on the interior because I'm just nervous about one burning out and then having to rip everything off again
Yup. I don't even notice that it technically isn't in the correct location (CL shifter bends, Accord doesn't for those who don't know). The throws are so much shorter, plus with the shifter bushings the shifts a much crisper. I just want to replace the Honda MTF with some Amsoil to see if I can rid that little bit of notchiness.
