can someone please answer this
Old Feb 4, 2003 | 05:30 PM
shakademus's Avatar
Do the ADR Sterling's 19/8.5 35 offset fit on the CL-S? Supposedly they fit on the Maxima. (Same bolt pattern) I know the offset is wrong but I'm not thinking about slammin my car anyways. would they fit if I rolled the fenders or something? I seen these rims on an Oddessy and it was rollin on 20's! Yes 20's. They stuck out a liiiiiiiiiittle bit, but it looked hot . I think these rims are HOT! and there on Ebay for like $900. Any advice would be greatly appreciated.
Old Feb 4, 2003 | 09:00 PM
Six Shifter's Avatar
an adult perspective
its not the bolt pattern that will give you problems, its the dimension of the center hub. the Maxima has a slightly larger diameter to the center hub than the CL does. if the wheels were designed specific to the Maxima application, than the wheel will not fit properly on your hubs and you'd need to see if anybody manufactures a centering hub which converts from the Maxima dimension to the smaller CL dimension, which I can't say does/does not exist.
Old Feb 4, 2003 | 09:34 PM
Nicky Pass's Avatar
Fuct in the hed!
NO WAY!!!! I have 19x8s with a + 45 offset...only on a Comptech drop, and I am SOOOOOOOOOOO close to rubbing
Old Feb 5, 2003 | 04:29 PM
shakademus's Avatar
But did you roll your fenders? I figure a 35 to 45 offset is 10mm. If you convert that to inches, it's .393". Am I right? Thats only about 3/8 of an inch. 3/8" is enough to make those rims not fit even if I roll my fenders? Anyone ever try to mount a similar setup? I'd hte to miss out on this deal because 3/8".
Old Feb 5, 2003 | 09:11 PM
mr. big's Avatar
i rubbed but i rolled the fenders and its all good now....19x8 and +45
Old Feb 6, 2003 | 04:07 PM
RaptorCLS's Avatar
Dromaeosaurs/Velociraptor
shakademus,
I'm looking into getting the 19x8.5 Zenetti....I'm hoping they will fit...they look awesome....otherwise I'll have to get the 18x8..goodluck man...post pics if you get'm working
Old Feb 7, 2003 | 02:21 PM
gsw1's Avatar
g-dub
Best 18" size?
What offset and width should I get with my Tein coilovers (not installed yet)?
gsw1
MoAbbas
Oct 3, 2015 07:44 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
LeVeL
Sep 21, 2015 06:57 PM
miguelalanis
Sep 21, 2015 01:04 PM
