2002 Acura CL-S with H&R OE Sport Springs
Hey guys,
Just wanted to thank everyone for helping me decide on the springs. Wanted to post some pics for you guys to take a look at, just dont thrash me too bad for the wheels. Thought they would look good but am having second thoughts...
http://home.earthlink.net/~twc937667...2acuracltypes/
I think it looks good.
Do you have any rubbing problems. I was thinking about getting those but Acura said that they will rub because of the offset. So I got the ones off a TSX instead.
AZ O.G NoOldManVetteOwner
If you didnt drop your car a bit, those 04 rims would have looked like crap. There are 2 2nd gen TLs on the TL site, one droped, one not dropped w/04 rims, and the one without the drop looked hideous. The problem is that the 3rd gen TL can handle alot more rim/tire size than the 2nd gen TL/CL, hence its offset isnt really correct.
However, your CL-S looks good. Best of luck.
The offset is perfect and there are no rubbing issues. The rims and tires a relatively cheap. I picked them up for $800.00 and they only had 5 miles on them. Were take-offs at an Acura dealership that did a A-spec package upgrade on an 04' TL. Make sure and go with the H&R "OE" sport springs #51858-55 for the drop you see on the picture. It measures about 1-1/4" all around. The handling is a little better but that great Acura rides stayes the same, no need for a camber kit either with only 1" drop.
The OE sport springs "51858-55" fit perfect. Matched all OEM specs and made for an even drop. Just make sure and re-use the factory spring isolators to eliminate squeeks. I used a expoy/glue to make sure they stayed on.
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
