2G CL Frequently Asked Questions No New Threads Please.
a trick to aligning CL mufflers
Old Oct 14, 2004 | 08:54 PM
mattg's Avatar
this will help to make the mufflers height adjustable. you need a couple hose clamps, size 7/8 - 2 3/4".
remove the rubber mount for the muffler (to make it slide off easy spray it w/ some wd40)
place the hose clamp around the rubber mount, then reinstall the mount in a fashion which allows you to adjust the clamp w/ a screwdriver.
once it's back on you should be able to tighten the clamp a few turns and even out your mufflers. it also helps to cut down on the side sway that our exhaust tends to have.
Old Oct 14, 2004 | 08:56 PM
mrsteve's Avatar
Will this also stop them from swaying back and forth?
EDIT: I didn't read to the end.
Old Oct 14, 2004 | 08:59 PM
mattg's Avatar
i have a clamp on both sides and my exhaust doesn't sway.
Old Oct 14, 2004 | 09:02 PM
mclarenf3387's Avatar
Good stuff I'll have to try that.
Old Oct 14, 2004 | 09:03 PM
mrsteve's Avatar
I'll be going to Home Depot tomorrow, thanks Matt!
Old Oct 14, 2004 | 10:07 PM
Allout's Avatar
Blown is Best
Excellent Idea. Send this to the FAQ thread.
Old Oct 14, 2004 | 10:27 PM
Chopsie's Avatar
Beware of leakage
We need after installed pics, Mr. Creative
Old Oct 14, 2004 | 10:42 PM
darrinb's Avatar
///M POWER
hmm, i dont understand
Old Oct 14, 2004 | 10:58 PM
Allout's Avatar
Blown is Best
The clamps will help you control the amount that the exhaust hangers extend thereby giving you adjustability into the height of the exhaust tips.
Old Oct 14, 2004 | 11:03 PM
NiteQwill's Avatar
Adventurist.
Haha, I did this to my VW exhaust, didn't know it would work on this car. Excellent!
Did you buy a set for all the hangers or only the rear?
Old Oct 15, 2004 | 05:22 AM
goldmemberer's Avatar
goldmemberererer
Hm. Anyone got pics or a DIY (for dummies) of how to do it? I noticed my exhaust pipes are hangin a little lower than I'd like, and this sounds so great to do.
Thanks in advance
Old Oct 15, 2004 | 07:23 AM
NSXNEXT's Avatar
Matt,
Nice post. I did this several years ago and they ended up snapping. The harsh weather took a toll on those clamps.
The best solution is to get under the car with a piece of pipe and slide the hanger bracket into the opening and bend the sucker into the right spot.
Old Oct 15, 2004 | 08:40 AM
bent09's Avatar
horny =
pretty smart.... now if I only had exhaust
Old Oct 15, 2004 | 08:59 AM
DHRJDMBA's Avatar
XSESIVE
Most of those clamps can be taken apart fully - you just unscrew it - wrap it around the rubber mount and tighten - saves having to take off the mufflers...
Old Oct 15, 2004 | 10:00 AM
Smitty's Avatar
.... those hose clamps come apart. no need to take it off..
But nice thinking Mattg..
Old Oct 26, 2004 | 08:01 PM
Shoofin's Avatar
I used to have clamps like that on my car, they kept breaking. Instead I doubled up on the exhaust hangers. I went to Strauss and bought these hangers that look like thin donuts, almost like a vaccuum belt, mounted it behind the stock hanger and it kept the exhaust properly aligned, and they didn't sway much after..
Ed
Old Jun 15, 2006 | 10:54 PM
jproy's Avatar
MP90 uninstalled
I am in louisiana and there are only Autozone pepboys napa, no strauss. do you know which part you bought? so I can get one at one of the stores around here.
thanks
Old Jul 25, 2012 | 12:16 AM
ejreams's Avatar
Genius!!!!
I just stumbled on this thread thank you!
Old Sep 5, 2013 | 02:58 AM
frank15p's Avatar
Cusco exhaust hangers will be my solution
Old Jul 14, 2017 | 02:56 PM
anthrag1's Avatar
5th Gear
...or you can also use zip ties to squeezed the rubber insulators too.
IBankMouse
Jun 13, 2020 12:53 PM
emailnatec
29
Sep 28, 2018 04:27 PM
DerrickW
Nov 15, 2015 05:52 PM
merc009
Sep 29, 2015 03:06 PM
johnpancakes014
Sep 27, 2015 12:58 PM
