Everybody post their rim size, tire, offset, etc in this thread, and FAQ this.
There were a couple off attempts of this before, though not very succesful.
If you need more info than in this thread, the TL board did the same.
http://www.acura-tl.com/forum/showth...threadid=15225
Please post your
1.Brand of Rim
2.Rim size
3.Offset
4.Brand of tire
5.Tire size
6.Drop amount
7.Do they rub?
7 questions, would honestly help a LOT of members, if answered.
The only reason you should not post is if your on stock rims on stock tires.
Please post your
1.Brand of Rim
2.Rim size
3.Offset
4.Brand of tire
5.Tire size
6.Drop amount
7.Do they rub?
i'm going to post all the sizes from the TL board, incase anyone searches, so we have it in our database, and it turns up on a search.
also, when you all use this , if you use it..remember the TL has A BIT less clearance than us..i think like 2mm
1. 17x7
2. +40
3. Kumho Ecstas
4. 205/50/17ZR
5. Comptech's very soon
6. I will let you know when I lower it, shouldn't be a problem. They don't rub now with stock springs.
19x7.5 +44 offset Racing Hart C-5's (3-Piece)
225/35/19 Nitto 555's
Nex CoilOver System
1.Rim size = 18" x 7.5"
Versus Turismo Spada = 26 lbs.
2.Offset = +52mm
3.Brand of tire =Michelin Pilot Sport
4.Tire size =225/45/ZR18
5.Drop amount =1.5" Comptech springs
6.Do they rub = Only the outside corner edge of my front tire (that's on the turning side) will rub on the plastic inside the front fender if I hit a dip or steep driveway too fast with my steering wheel turned all the way to one side - when the dampers & springs compress and the weight is on the front. So I try not to do that. That's cuz I got 45 series tires and they're .29" taller than stock. I need to get stiffer shocks or coilovers?
1.Rim size: (17" X 7" CL-S Wheels)
2.Offset: (55)
3.Brand of tire: (Bridgestone RE730)
4.Tire size: (225/45/17)
5.Drop amount (none yet)
6.Do they rub. (nope)
1. 18x7.5 Axis Se7ens
2. 42 offset
3. 225/40/18 Kumho Ecsta 712
4. Ground Control Coilovers (2.0/1.5)
5. Rubbing In the Back and the Front Tabs (Rolled Fenders/Pushed Back Tabs) Very Minor Rubbing with 4+ People.
1. 17 x 7
2. +48 (I think)
3. Goodyear Eagle HP Ultra
4. 215/45/17
5. None yet. I will be ordering Comptech springs and sways soon
6. Uh...no.
1. Kosei S5R
2. 17x7
3. 48mm
4. Michelin Pilot XGT Z4
5. 225/50
6. 1.25" front / 1" rear
7. Not any more. Rear only: had to trim plastic bumper and roll fenders. Fronts, no problem.
1.Alstadt
2.18 x 7.5
3.+53mm
4.Kumho
5.225/40/18
6.3" drop
7.Doesn't rub at all
1. Lowenharts
2. 18 x 7.5
3. 48
4. NT555
5. 225/40
6. ~3.5 inches with apexi ws coilovers
7. sometimes.. bouncy roads
stock rims
Goodyear Eagle HP Ultra Plus
225/55/16
will do H&R Sports
nope
1.Brand of Rim - Racing Hart C2
2.Rim size - 18x8
3.Offset - +50
4.Brand of tire - Dunlop SP9000
5.Tire size - 225/40ZR18
6.Drop amount - 1.5" Comptech springs
7.Do they rub. - No rubbing...no buffing...It's a floor wax and a dessert topping
http://i17.yimg.com/17/5f64d549/h/203d6c1c/012_9a.jpg
1.Brand of Rim - Tecno Motor Works Scuderia 2.Rim size - 18x7.5
3.Offset - +47
4.Brand of tire - Pirelli P7000 SS
7.Do they rub - No.
1.Brand of rim: SSR GPO Evolutions (3-piece)
2.Rim size: 18x7
3.Offset: +49
4.Brand of tire: Nitto 555
5.Tire size: 225/40-18
6.Drop amount: 1.75" Neuspeed Sports
7.Do they rub: Nope
1.Brand of Rim-CL Type S Rim
2.Rim size-17x7
3.Offset-55
4.Brand of tire-Toyo Proxes TS1
5.Tire size-215/50/17
6.Drop amount-Comptech drop Approx. 1 1/2 front 1 1/4 rear
7.No they do not rub.
1. Konig Tantrums
2. 18
3. +42
4. Yokohama Parada
5. 225/40/18 ZR
6. Comptech Springs (1.5"")
7. Once in a while when 3 people are in the back seat.
1. BBS RKII
2. 17x7.5"
3. +44
4. Bridgestone Potenza S-02
5. 225/45/17 ZR
6. Eibach Prokit (1.75"") w/Koni Yellow adj
7. Nope, no rubbing so far (fender rolled)
1. Lowenharts LGM (3 piece) Chrome
2. 18 x 8
3. 48
4. NT555
5. 225/40 ZR
6. 3 - 3.5 inch drop (apexi n1 ws coilovers)
7. doesn't rub, only when its a bouncy road..
wish i got a higer offset tho, heard they had a 60mm offset on these rims dayem how come they didn't tell me, argh!!! i could be riding even more slamned and never have to worry about rubbing with a 60mm offset (higher then stock offset)
Brand of Rim: Altstadt IV
Rim Size: 19x8.0
Offset: +47
Brand of tire: Yokohama AVS Sport
Tire size: 235/35ZR19
Drop amount: Comptech
Do they rub: I cut the plastic tab from the fender but they still rub with more than 3 people in the car if I'm taking a corner much faster than I should be going.
Rim Weight: 25.125 pounds
1. ADR GT Sport
2. 18x7.5
3. +42
4. Kumho Ecsta
5. 225/40ZR18
6. eibach - 1.25"
7. no rub after I got the fenders rolled. (little in the back before, though)
I've been posting earlier that my offset was +40, but it's really +42. My bad!
1. Volk Racing Versus Campionato SS7
2. 18x7.5
3. 52 offset
4. Toyo Proxes FZ4
5. 225/40/18
6. 1.5 w/ Comptech Springs
7. Noh!
1. Alba Blaze
2. 18x7.5
3. +42
4. Falken
5. 215/40
6. No Drop
7. DO NOT RUB!
1. ALT 180
2. 18x7.5
3. ?
4. ?
5. 225/40
6. H&R Sports 1.75"F 1.5"R
7. No Rub with this tires, but used to rub with same 225/40 but different brand. (The back only)I had four people in the back(about 600lb)the other day. My tire was inside the fender, the wall of the tire was about less than a 1 mm from the inside of the fender. Couldn't fit a credit card between the tire and fender. No problem in the front with either tire.
1. Brand of Rim - 5zigen 3-piece Heidfeld w/ custom chrome rivots
2. Rim size - 18x7.5
3. Offset - +48
4. Brand of tire - Nitto NT-555
5. Tire size - 225/40ZR18
6. Drop amount - Comptech springs
7. Do they rub - Nope
1.Brand of Rim - Konig Impakts
2.Rim size - 17 x 7.5
3.Offset - +42
4.Brand of tire - Yokohamas
5.Tire size - 225/45/17
6.Drop amount - 1.2 (before settling)
7.Do they rub - not after fender trim, but before it did rub a bit
BRAND- Altstadt I - Silver Mesh
SIZE- 17x7.5 inch
OFFSET- +48
TIRES- Bridgestone Potenza RE-730
SIZE- 225/45-17
DROP- Comptech Springs, about 1 inch
RUB- Nope, not yet at least.
1.Brand of Rim- Acura CL-S
2.Rim size- 17x7
3.Offset- +55
4.Brand of tire- Michelin
5.Tire size- 215/50/17
6.Drop amount- 1.25" Eibach Pro Kit
7.Do they rub.- No rubbing...even with 5 people and hard corners
1. Brand of Rim - AT Italia S5
2. Rim Size - 18x7.5
3. Offset - +50
4. Brand of Tire - Bridgestone Potenza RE730
5. Tire Size - 225/40/18
6. Drop Amt - 1.5" rear, 1.75" front (Comptech springs)
7. Do They Rub - They did with anyone in the back until I cut off the little plastic tab that sticks out under the rear wheel well.
5zigen Heidfelds
17x7
+48
Nitto 455 225-45-17
Comptech Springs
no rubbing.. just some sweet ass cornering & handling
Brand of rim: Volk Racing Vesus Champion SS7 (Gunmetal)
Rim Size: 18x7.5
offset:+44
Brand of tire: Pirelli P7000ss
Tire size: 225/40/18
drop amount: H&R sport spring 1.75front and 1.50 back
Do they rub: yes a little i roll my fender
Brand of Rim: AT Italias5
Rim Size: 18x7.5
Offset: +50
Brand of tire: Michelin Pilot Sport
Tire size: 225/45ZR18
Do they rub: Never, even with 5 people and hard turns
Rim Weight: lighter than stock.
AT Italia Flash Silver
17x8
+50 Offset (I think)
225/50-17
Michelin Pilot XGT-Z4
No Drop, Yet
Do not rub
1. Enkei Aegis
2. 19 x 7
3. +45mm
4. Toyo Proxes FZ4
5. 235/35/19
6. 2.5" drop
7. Only rubs w/4 people on bumps.......
1.Brand of Rim:RacingHart C5 3piece/VolkRacing GT-P Diamond cut
2.Rim size: 18" by 8" / 17" by 7"
3.Offset: 52 / 44
4.Brand of tire: Pirelli P7000 SS / Sumitom HTRZ II
5.Tire size: 225/40/18 / 225/45/17
6.Drop amount: Comptech 1.5
7.Do they rub.: No/No
1. CL Type-S Wheels(made by Enkei)
2. 17x7
3. 55mm
4. Dunlop SP9000
5. 225/45/17(soon to have 235's..no they don't rub either)
6. Comptech 1.5" front, 1.25" rear
7. Zero rubbing whatsoever.
Ed
18x8.5 Giovanni Essens Chrome
225/40 18ZR Parada's
45+ offset
Apexi Coilovers w/ WW kit
dropped to th floor and no rubbin
BLITZ Technospeed Z2
18x8 +45 offset
Pirelli P7000SS 225/40/18
H&R SportSpring 1.75" 1.5"
no rubbin
1. Lowenhart BR5 (chrome)
2. 18x8
3. +50
4. Toyo Proxes T1-S
5. 225/40/18
6. H&R Sport Springs
7. no rubbing
1. 5Zigen Copse
2. 18x7.5
3. +49
4. Pirelli P7000SS
5. 225/40/18
6. Comptech Springs
7. Nope.
__________________
1. AME Modelart
2. 18 x 7.5
3. +47mm (shop claims to have customized from a +45)
4. Pneumann (never heard of this brand; think i got jacked)
5. 225/40/18
6. Eibach Prokit (2.1" , 1.65")
7. The rear rubs (after cutting out all the tabs no more rub)
In my opinion:
Note: Some people are running 18 x {8} with a 45+ offset with no rub on 225/40/18 w/ drop. How are you guys getting away with no rub? For those who are uncertain of wheel offset i recommend not going with anything smaller than +47 on my setup (above) if you do not want to have your tires rub.
1.Enkei AKA'z
2.17X7.5
3.+39
4.NT450 225/50/17
5.No droppage
6.Yea it did scrub, because i was concerned about premature miles being added to my car... I think ill drop to 225/45 when I get my new tires... I did fix the scrub in tha back with a dremel and it doesnt scrub anymore, the only thing it did scrub was rubber from the top part of the rear bumper... I shaved it and it looks nice, you cant even tell...Shyne
1. Volk Racing GTP
2. 18x7.5
3. +49
4. Pirelli P7000
5. 225/40/18
6. H&R Sport
7. No rubbage whatsoever (w/ 4 people in the car)
1. Panther 175
2. 18x8
3. +43
4. Pirelli P7000SS
5. 225/40/18
6. Ground Control Coilovers- 3" drop
7. No rubbing whatsoever after cuttin the little fender tabs even with 5 people in the car!
I was pretty surprised that I didnt have to roll the fenders or anything like that. Most people said it would rub and it doesn't.
1. Giovanna Corsica
2. 18x7.5
3. +45 offset
4. Toyo T1-S
5. 225/40
6. Comptech Springs
7. no rubbing, no cutting
1 Kosei Seneka
2 18x7.5
3 not sure-bought from the Acura dealer
4 Kumho 225/40
rubbing when 2 adults in back when going over a speed bump
1. Momo Quasar 2
2. 17X7
3. +45 offset
4. Michelin Pilot XGT H4 215/50/17
5. Stock suspension
6. Rubbing with two passengers going over bumps
I guess I'll have to cut or file down the bumper tabs in the rear wheel well.
1. Cdn speck stock TLS
2. 17X7
3. +55 offset I think
4. Firestone Firehawk SZ50 245/45/17
5. Stock suspension
6. No rubbing
1. KONIG VERDICT
2. 18 X 7.5
3. + 45
4. KUMHO ECSTA SUPRA 712
5. 225/40/ZR18
6. 1.75 FRONT, 1.5 REAR
7. NO, NOT SO FAR
1.Rim size: (19" X 8" Axis SE7EN's)
2.Offset: (+40, but +45 is available and probably better)
3.Brand of tire: (Falken ZE-502 cheap, but very impressive)
4.Tire size: (235/35/19)
5.Drop amount: (Comptech springs, initial drop was 1.5" front and .75" rear, waiting to see if they settle)
6.Do they rub. (had to cut a VERY small part of the plastic on the rear part of the rear inner fender well, now there is absolutely no rubbing, +45 to +48mm may prevent it completely without cutting)
7.Weight: (28 lbs w/o tires.)
volk racing f-zero kuwagatas, 18x7.5, +42mm
pirelli p7000ss, 225/40/18
eibach pro-kit, 2.1"/1.6"
rubs a little bit mostly at left rear tire (will take care of it soon)
Wheels: Zenetti saphire
size : 18X8 +42 offset
Tires: Toyo proxies 224/40/18
Drop: 2.5 inch,eibach pro kit,koni sports(yellow)
Rub : No rubbing whatsoever
19x7.5 SSR Agle Minerva
Dunno offset, i think +42 or +47
Nitto
225/35/19
no drop yet
nope
1.Racinghart M5 3 peice
2.19x7.5
3.+51 offset
4.Yokohama AVS sport
5.235 35 r19
6. .75 inch drop
7. no rub even with 5 people. no cutting or rolling needed.
-DAZZMATIZ
-19 X 8
-48 OFFSET
-TOYO PROXES
-235/45
-1.75 EIBACH PRO KIT
-ROLLING FENDERS THEY ONLY RUB WHEN PEOPLE IN BACK SEAT AND HARD TURNS.
1.Rim size: 17x7 Momo Quasar II (Chrome)
2.Offset: 45mm offset
3.Brand of tire: Bridgestone Potenza S-02 Pole Position
4.Tire size: 235/45/17
5.Drop amount: Comptech Drop Springs 1.25" front, 1" rear
6.Do they rub: Yes, I need to get the rear qtr panel lip roled.
7.Weight: Don't know
1.Brand of Rim-- Volk Av3
2.Rim size--18x8
3.Offset-44 or dunno
4.Brand of tire---mich. pilot sports
5.Tire size--235-40-18
6.Drop amount ---1.75 front and back
7.Do they rub- Yes they rub but not badd. front and back. shaved rear plastic and rolled fender. need to get new tires..
1. 17x7
2. +40
3. Kumho Ecstas
4. 205/50/17ZR
Nex CoilOver System
2.Offset = +52mm
2.Offset: (55)
2. 42 offset
1. 17 x 7
2. +48 (I think)
4. 215/45/17
6. Uh...no.
1. Kosei S5R
2. 17x7
3. 48mm
5. 225/50
1.Alstadt
2.18 x 7.5
3.+53mm
4.Kumho
5.225/40/18
6.3" drop
1. Lowenharts
2. 18 x 7.5
3. 48
4. NT555
5. 225/40
stock rims
225/55/16
will do H&R Sports
nope
2.Rim size - 18x8
3.Offset - +50
3.Offset - +47
7.Do they rub - No.
2.Rim size: 18x7
3.Offset: +49
7.Do they rub: Nope
2.Rim size-17x7
3.Offset-55
1. Konig Tantrums
2. 18
3. +42
4. Yokohama Parada
5. 225/40/18 ZR
1. BBS RKII
2. 17x7.5"
3. +44
5. 225/45/17 ZR
2. 18 x 8
3. 48
4. NT555
5. 225/40 ZR
Rim Size: 19x8.0
Offset: +47
1. ADR GT Sport
2. 18x7.5
3. +42
4. Kumho Ecsta
5. 225/40ZR18
6. eibach - 1.25"
2. 18x7.5
3. 52 offset
4. Toyo Proxes FZ4
5. 225/40/18
7. Noh!
1. Alba Blaze
2. 18x7.5
3. +42
4. Falken
5. 215/40
6. No Drop
7. DO NOT RUB!
1. ALT 180
2. 18x7.5
3. ?
4. ?
5. 225/40
3. Offset - +48
3.Offset - +42
SIZE- 17x7.5 inch
OFFSET- +48
SIZE- 225/45-17
2.Rim size- 17x7
3.Offset- +55
3. Offset - +50
5zigen Heidfelds
17x7
+48
Nitto 455 225-45-17
Comptech Springs
Rim Size: 18x7.5
offset:+44
Rim Size: 18x7.5
Offset: +50
17x8
225/50-17
No Drop, Yet
Do not rub
1. Enkei Aegis
2. 19 x 7
3. +45mm
4. Toyo Proxes FZ4
5. 235/35/19
6. 2.5" drop
3.Offset: 52 / 44
2. 17x7
3. 55mm
4. Dunlop SP9000
Ed
45+ offset
18x8 +45 offset
no rubbin
2. 18x8
3. +50
4. Toyo Proxes T1-S
5. 225/40/18
7. no rubbing
1. 5Zigen Copse
2. 18x7.5
3. +49
4. Pirelli P7000SS
5. 225/40/18
6. Comptech Springs
7. Nope.
__________________
1. AME Modelart
2. 18 x 7.5
5. 225/40/18
In my opinion:
1.Enkei AKA'z
2.17X7.5
3.+39
4.NT450 225/50/17
5.No droppage
1. Volk Racing GTP
2. 18x7.5
3. +49
4. Pirelli P7000
5. 225/40/18
6. H&R Sport
1. Panther 175
2. 18x8
3. +43
4. Pirelli P7000SS
5. 225/40/18
1. Giovanna Corsica
2. 18x7.5
3. +45 offset
4. Toyo T1-S
5. 225/40
6. Comptech Springs
1 Kosei Seneka
2 18x7.5
4 Kumho 225/40
1. Momo Quasar 2
2. 17X7
3. +45 offset
5. Stock suspension
2. 17X7
5. Stock suspension
6. No rubbing
1. KONIG VERDICT
2. 18 X 7.5
3. + 45
5. 225/40/ZR18
7. NO, NOT SO FAR
Nitto
225/35/19
no drop yet
nope
2.19x7.5
3.+51 offset
5.235 35 r19
6. .75 inch drop
-DAZZMATIZ
-19 X 8
-48 OFFSET
-TOYO PROXES
-235/45
2.Rim size--18x8
Community Architect
robb m.
robb m.
Volk Racing SE37K
18x7.5"
Offset=48mm
Pirelli
235/40/18
Comptech Springs or H&R Springs
minor rubbing with these rims on the CL-S but major rubbing with them on the TL-S.
18x7.5"
Offset=48mm
Pirelli
235/40/18
My other car is a 350Z
1. SSR Competition
2. 17x8"
3. +48
4. Toyo Proxes T1-S
5. 225-45/17
6. Comptech (1.5" front, 1" rear)
7. No rubbing whatsoever on current setup.
When I had 235-45/17 Toyo Proces T1-S they rubbed in two places on the upper-inner portion of both front wheel wells during full lock turns over slightly irregular pavement. Rubbing was minor (no visible damage to tires after 3100 miles) but sounded terrible.
2. 17x8"
3. +48
4. Toyo Proxes T1-S
5. 225-45/17
The Creator
Re: Everybody post their rim size, tire, offset, etc in this thread, and FAQ this.
1.Brand of Rim: Axis Se7en
2.Rim size: 19x8
3.Offset: +45
5.Tire size: 235/35-19
6.Drop amount: Ground Control Coil-Overs: 2+ inches (est.)
7.Do they rub? Yes, under hard cornering (abrupt 90 degree turns) or going over speedbumps at 40mph.
2.Rim size: 19x8
3.Offset: +45
Re: Re: Everybody post their rim size, tire, offset, etc in this thread, and FAQ this.
1.Brand of Rim: RH Evo C2
2.Rim size: 18 x 7.5
3.Offset: +42
4.Brand of tire: Bridgestone Potenza SO2
6.Drop amount: Eibach Prokit
7.Do they rub? Yes, only in the rear. Had to roll inside fender lip and dremmel small amount of plastic.
3.Offset: +42
STi
1.Brand of Rim> Rota
2.Rim size> 17X7.5
3.Offset> +42
4.Brand of tire> Kumho Ecsta 712 Supra
5.Tire size> 225/45/17
6.Drop amount> Not Yet
7.Do they rub?> I said not yet![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
2.Rim size> 17X7.5
3.Offset> +42
235 OK (Possible move to 245/40 later)
1. SSR Competition
2. 17x8"
3. +48
4. Toyo T1-S Proxy
5. 235/45ZR17-97W*
6. Stock/factory/OEM springs
7. No rubbing -- ever (even in hard rights and left at speed with FULL load)
See sig for load rating etc.
Would consider Technique's setup of 245/40ZR17-95W* T1-S (as future update) if not lowered (and he seems to be doing fine with the even larger tires without lowering springs).
2. 17x8"
3. +48
4. Toyo T1-S Proxy
5. 235/45ZR17-97W*
Subie Dubie
My new wheels are gonna be in any day now.
1. Volk TE 37s
2. 18x7.5
3. +48
4. Toyo Proxes T1-S
5. 225-40-18s
6. Comptechs
7. Doesn't sound like it from all of these other posts.
1. Volk TE 37s
2. 18x7.5
3. +48
4. Toyo Proxes T1-S
5. 225-40-18s
6. Comptechs
Konis + setup = rubbing
Originally posted by H@mmerm@n
1. SSR Competition
2. 17x8"
3. +48
4. Toyo Proxes T1-S
5. 225-45/17
1. SSR Competition
2. 17x8"
3. +48
4. Toyo Proxes T1-S
5. 225-45/17
Mike, it probably would help people to know (as you and I know) that Technique and others have tried the same setup (minus the Konis) and had no rubbing.
In addition, there is Water Rabbit with:
1. HRE
2. 17x7.5"
3. +52
4. Toyo T1S Proxies
5. 235/45ZR17-97W*
6. Comptech springs (on the car a while)
7. No rubbing reported
A BIG NOTE SHOULD BE ADDED TO THE SSR Competition + 235/45-17 Toyo + Comptech spring setups that say: "Possible rubbing when used with Koni Yellows"
Re: Konis + setup = rubbing
1. HRE
2. 17x7.5"
3. +52
4. Toyo T1S Proxies
5. 235/45ZR17-97W*
1. HRE
2. 17x7.5"
3. +52
4. Toyo T1S Proxies
5. 235/45ZR17-97W*
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
