J35 12:1 CR Dyno
J35 12:1 CR Dyno
Drove out to xact dyno in Phoenix today. Made 289.6 whp and 260 ft lbs torque.
As evident from the graph, hp climbs steadily to around 6300. But, torque falls sharply from around 5000 on. I had hoped to make 300hp, but it seems the 3" cat is holding the motor back.
In any case the car drives a lot better than before the tune, with an aggressive take off, yet pretty tame and mild when cruising. AC, heat, power steering and heated seats still work as they should.
dyno clip here:
https://youtube.com/shorts/yvRToYQ1kZg?si=EnSIkaIECMiOmarE
dyno clip here:
The following 3 users liked this post by 619rcr:
So after coming up short on whp decided to order a higher flowing cat. This is what I went with:
Xforce 200 cell 3" cat
Will be welding it up here shortly. I'll spare the amateur weld pics.
Thefireball (03-26-2023)
fpique
14
10-11-2004 09:50 AM
