wrong plugs
Old Oct 11, 2010 | 11:32 AM
PANAMARED's Avatar
wrong plugs
Just replaced plugs in my 01 CL-S. I should have used the PZFR6E-11 (which are a bit hotter for the type S model) but had to install PZFR5F-11 which are for the CL-P. Is there a noticeable difference in performance? Does anyone strongly reccomends to replace with the correct temperature plug?
Old Oct 11, 2010 | 12:34 PM
StreetKA's Avatar
Only iridium NGK. Thats the right way to go.
Old Oct 11, 2010 | 01:23 PM
PANAMARED's Avatar
I used the Iridium IX but the temperature number is 5 (cooler) for the CLP - I had to install those - should have used the Iridium IX but temperature number 6 (correct for the type S, a bit hotter than the ones CL-P uses). I ask this because my car is definitely going to be running better (replaced a bunch of stuff that was needed) but still have the annoying doubt that with the correct plug it should be performing even better (that thought keeps bugging me). I have reviewed a few posts about the spark plugs but still not clear if there is a definite noticeable difference.
Old Oct 11, 2010 | 02:06 PM
Rajca's Avatar
wham bam thank you ma'am
Other way around. Higher number the colder the plug.
Old Oct 11, 2010 | 02:12 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Only for ngk plugs. All other plugs temps are reversed
Old Oct 11, 2010 | 02:53 PM
MIKE8898's Avatar
Bonki Ehrite!
NGK is the way to go IMO. Spark plugs is something i don't cheap out on.
Old Oct 11, 2010 | 03:31 PM
PANAMARED's Avatar
I am not being cheap using the CL-P plugs, they were sent wrong and i can not exchange them... I have to buy new ones in order to replace. Should I forget about that and just leave the ZFR5FIX-11 that are installed new or should I spend my $ again and buy the ZFR6FIX-11. Does anyone know if there is a noticeable difference in performance?
Old Oct 11, 2010 | 07:28 PM
ChucksCL-S's Avatar
A spark is a spark.....the 6FIX plugs are COLDER plugs which means they transfer more heat to the heads than the 5FIX plugs. So will your engine run too hot now? I doubt it, only if you are making 1/4 mile runs every weekend at the track then I would switch them out. With winter coming, I'd say don't worry about it.
Old Oct 12, 2010 | 09:31 AM
PANAMARED's Avatar
Thanks Chuck! I know my issue was kind of stupid but it kept bugging me... my CL-S is running great, even feel milage improvement.
Old Oct 12, 2010 | 09:49 AM
typeR's Avatar
whys everyone saying NGK anyway ... i always ran densos IK22 im in florida
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
