wow what a save...and a wake up call
my rear tires,formerly my fronts are slicks....i mean 0 tread...but ive been thinking of 18's and having these for the track,so i didnt wanna buy tires yet,so it's raining and i coming home,slow sweeper 30 mph and the rear end just swings out...i steer into the skid immediately,it comes back around and kick out the other direction but not as much,steer back into that skid and straighten her out...im still shaking...but i learned two things...i reacted well and i need to do something asap about the tires
Originally Posted by 03 CL TypeS
Anyone remember the thread where one guy argued he should put the new tires on the front of his CLS, and the old ones on the back?
in this case, sounds like all the tires were shot.
i need tires
I think you missed my point bro.
On a FWD vehicle, the tires with the most traction should be in the back, not the front. But don't take my word for it - check out what all the major tire manufacturers say about that!
i've always heard that the better tires should go in the front regardless if it's a FWD or RWD. if you have bald tires in the front, how u gonna stop/turn?
yup and this is a good case in point-if typer couldnt steer out of it he would have been in big trouble.
do you think an "average" driver could have saved that car??
thats why your best tires go in the back cause you cant correct it as naturally or as easily as you could the fronts losing traction
glad your ok thats some scary shit when it happens unexpectedly
If your fronts lose traction your FUCKED!!!! You won't be able to steer the vehicle if you have no traction in the front, hence grippy tires go upfront.
It just so happens that our cars extreme front weight bias and shitty tires in the rear will cause the rear stepping out in otherwise normal conditions.
Hey! I got a great idea, get new tires all around! That means replace all 4 when they reach 2/32... How friggin stupid do you have to be? Get a clue, bald tires and driving in the rain is just a recipe for either trashing your car, injuring or killing yourself or someone else.
there's no doubt i need tires but...in a FWD vehical good tires go up front period...as far as the tires save the lectures,everyone knows how much i drag race,and i explained i was wanting to go 18,anyone that knows florida...one minute sunny one minute...
Originally Posted by mrsteve
He no longer has VSA and VSA has no control over the rear wheels.
vsa is more effective on rwd or awd cars because it can cut power to the rear (engine braking begins) and that helps quite a bit.
Vsa
VEHICAL STABILITY ASSIST (VSA) SYSTEM
First equipped in the 2000 model year Acura 3.5 RL flagship sedan, the Acura Vehicle Stability Assist (VSA) system is standard equipment on the 3.2 CL Type S model. Similar to the 3.5 RL system, the CL's VSA system orchestrates the throttle and brakes to seamlessly integrate traction control, anti-lock braking and stability enhancement processes. This innovation is designed to assist the driver in maintaining control during acceleration, cornering and sudden collision-avoidance maneuvers by applying braking force to the right or left front wheel as necessary and managing the throttle system.
By monitoring input from eight vehicle sensors, the VSA system can calculate a predicted range of vehicle response while constantly monitoring the vehicle's actual response and the driver's control inputs. If the actual response is outside the predicted response range -- as when cornering forces exceed the tires performance, for example -- VSA automatically intervenes with corrective action. In the case of oversteer (which may lead to spin), VSA applies braking to the outside front wheel to counter the unintended yawing tendency. On the other hand, if understeer becomes pronounced, VSA applies braking to the inside front wheel and reduces engine power to turn the car back into the intended course.
Unlike some vehicle stability systems, which can seem intrusive to enthusiast drivers, the Acura VSA is calibrated to add to stability and predictability, without stifling the driving enjoyment of the CL's carefully engineered chassis and double wishbone suspension. An indicator light flashes on the instrument panel while the system is actively enhancing the stability of the vehicle. A cockpit switch is provided to disable the VSA and TCS while leaving the antilock braking system fully functional.
On a FWD vehicle, if replacing only 2 tires, the new tires must go on the back.
If you disagree with this statement, you also disagree with the recommendation of any reputable tire manufacturer out there.
I rest my case.
I rest my case.
Originally Posted by paulff3
New tires always go on the back. There have been some good articles in Car and Driver recently on this. Lots of people get this one wrong.
Went to Discount Tire recently and they were saying that to me as well.
I rest my case.
I rest my case.
I wish i had gotten this info about the good tires being in the back before i spun on the highway 7am in the morning just about to exit. I went from the HOV lane to the grass on the other side hitting a speed limit sign saying 55mph and i was doing 70mph
Funny thing is i should have leant my lesson when a similar thing happened to me while driving from CT to GA, i hydroplaned in NC which wasnt as scary as this one cos there was no traffic on the road.
But am glad u have learnt from this lesson and i hope alot more ppl read this and take more care driving in the rain .
You're supposed to drive with passenger tires on public roads, not racing slicks!
http://www.atomicdesigns.com/shawn/mov00003.mpg
http://www.atomicdesigns.com/shawn/typeR_086.mpg
I'm at work now so I can't check the vids. I'm guessing a massive burn out turned them into slicks.
When your front tires have a lot more traction around a curve than your rear tires, your back end will spin out spontaneously and it's extremely difficult to control it, if not impossible. That's why they recommend to put the better tires in the back. You can avoid understeering by having a slower entry speed in the corner, and by laying off the throttle once you're already understeering... but once your back end kicks out on a FWD... you know first hand what happens. Had your slicks been in front, and your passenger tires in the back, you would have understeered but definitely wouldn't have spun out like that!
Originally Posted by typeR
they started out as passenger tires.
I wanna do burnouts like that
From Michelin
"Where do I install new tires if I only buy two?
If you're replacing only two tires, be sure to have them installed on your vehicle's rear axle. New tires will provide better grip than your half-worn tires and when they are installed on the rear that helps reduce the potential for your vehicle to fishtail or hydroplane in wet conditions."
http://www.michelinman.com/care/tip6.html#5
Should pretty much wrap this up.
Paul
Paul
From Michelin
Paul
Paul
that would be true if it were rear wheel drive ...re ask the question
What happened to you, is a perfect example of what happens when rear tires have significantly less traction than front tires in a FWD car.
Just as true for FWD as for RWD.
if the tires were reversed i would have gone straight off the road ...end of story
As far as the end of the story is concerned, you're not supposed to drive around with bald tires on the street because you're putting your life, and the lives of others in danger.
If you had proper tires, you wouldn't spun out, nor gone off the road.
You're correct about that.
I rest my case.
I rest my case.
thank you
