Wow 23 WHP and 24 lbft from UR pulleys on AV6 (with CAI)!
Happy CL-S Pilot
Very Impressive results from UR pullyes...
Here the numbers:
STOCK HP = 150
WITH UR PULLIES = 173
STOCK TORQUE = 141.9
WITH UR PULLIES = 165.8
Here is the link:
http://www.v6accord.com/forums/showt...5&pagenumber=4
Here the numbers:
STOCK HP = 150
Here is the link:
Full-Time IDIoT---DoH!!!
Originally posted by Zapata
Well that accord engine isn't exactly tuned so i guess its possible. Remember comptech exhaust gives accords 10hp so it's possible.
p.s. I think my friend from av6.com would have had higher #s because he is running on some heave ass chrome rims lol
Cost Drivers!!!!
NOOOOOO!!!! Don't do it!!! Aftermarket pullies aren't balanced and are not meant for daily driving. You will do damage to the engine, leak oil etc., AEM and Unothrodox will tell you that these things are for race application only. Alternator pully is one thing but don't foq with the crank pully.
Nitrotiger has some experience with this so hopefully he will read this thread and share his knowledge.
Those HP #'s are ridiculous on the UR"s!
I LOVE MY CAR
I'm a little skeptical here... does anyone know what the CAI added to this number?? Is there a dyno of an AV6 w/CAI only??
I hope it's true
, but find it a little hard to believe...
DOM
I hope it's true
DOM
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Originally posted by Nex
I thought the crank pulleys were a problem only on the 4bangers, and not the V6's? Something to do with the inherent balance of the engine of the V6s?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
However, I remember someone posting on the maxima forums that most maxima owners who have had UR pulleys haven't had any problems and have either seen no gains or big gains. The safe bet would be change all the pulleys but the crank IMO.
First of all...I need the Honda V6 gurus to educate me. Does the stock crank pulley also serve as the harmonic balancer or just a vibration dampener.
Second of all, I must say I am pretty skeptical that pulleys gave this much of a gain. I'd like to see more details such as correction factors on the two runs and whther they were at the same dyno, etc.
Cost Drivers!!!!
Originally posted by unsure
Like the tech-guru Zapata said
, the crank pulleys are unbalanced and would affect the harmonic resonance in any type of car regardless of # of cylinders. However, crank pulleys (aftermarket ones) have an even more adverse affect on inline engines (i.e. BMW straight 6 cyl. engines) then on v6, but v6s are usually affected eventually.
Oh thanks for the compliment but i must say my mentors and gurus are Scalbert, EricL, Nitrotiger, Xenon7 and the rest of the wrench heads. I waiting for one of them to address this issue.
Xe- For Better Hwy Vision
Ok, I'll bite.
. . .real quick, Save the money! Every heard the expression
"the gift that keeps on giving" well, this is the gift that keeps on giving headaches in some cases.
Underdrive pullies are really made for specific short time uses, i.e. the track, not as daily driver applications. AEM has designed their pullies within a reasonable tolerance, but yeild little gains as we have seen. The main problem still exist with the alternator turning slower, it won't be able to produce the current needed to keep the battery charged when running at idle. Not good for city people!
Changing the crank pulley might have negitive effects over time with pre-mature bearing wear. Also the pulley metal thickness is less on some of the manufactures than stock which would present balancing issues if not installed with the right gauges.
and checked periodically.
I don't want to beat this thing to badly with the negitives. I know there has been many discussions and for certain setups, it has it's place. IMO I would drop the money into something that really has some benefit. ex. Suspension, tires
Any other thoughts?
Any other thoughts?
![Bandito](https://acurazine.com/forums/images/smilies/bandito.gif)
Originally posted by xenon7
Ok, I'll bite.
Any other thoughts?
Ok, I'll bite.
Any other thoughts?
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
joflewbyu2
10-08-2015 11:16 AM
